After many weeks of testing with first a B5442 varifocal and then a T5442 fixed (2.8mm, 3.6mm and 6.0mm), I'm trying to finalize the testing phase of our install of five outdoor cameras. The biggest problem we are stumbling on is the front entry area. The coach lights on both sides of the door are causing too much flare for night time images because the camera is pointing straight towards the door. I was warned ahead of time by poster Looney2ns that this was going to be a problem, and he was right as usual, but we can't seem to find a workable solution so I'm reaching out to the forum for help. The day time image is great. The main purpose of this camera view is to monitor porch pirate activity, door kick-in activity but mostly to see who is at the front door since we don't answer the door unless we are aware of a visitor or delivery. One thought is to figure out a way to dim these two coach lights. All coach lights (qty 5) are on one circuit and we want to maximize light output at the other locations. The entry lights each have a single LED bulb, 3.3w (40w equivalent). 2700K softwhite, 300 lumens. One thought is to do some type of frosting of the lamp side glass or find a frosted bulb that puts out less light. We also have the incadescent 25w bulbs that were there before the LEDS so we can try those for testing purposes.
There will be a camera positioned that captures the approach to the entry area and we are contemplating moving that camera from the original eave position (Location A) at about 90" to a lower level birdhouse (Location B), about 36" off the ground. In theory this would capture a good face shot before the person enters the entry area. We are pretty well sold on the birdhouse solution but that means running conduit underground, so it's preferred that the entry solution match to avoid running conduit underground and also along the eaves, double work, but possible. I guess this is a second question in terms of what's best for the pad location camera, Location A or B.
Attached are a group of pics showing the entry and pad and snapshots off of video when testing.
ENTRY AREA
Location A and B are on the stucco. Location A hides the camera better and makes running conduit easier and less obvious. Location B conduit isn't very good looking. Location C would be in a birdhouse mounted on a pole with conduit running underground. If we run conduit underground for Pad Location B, it would be easier to continue that run to Entry Location C just a few feet away.
PAD VIEW
We have tested two locations, Location A under the eaves and Location B in a birdhouse. As mentioned above, Location B offers a nice low position to capture a quality face image and we're leaning towards that location.
Sorry for the long post. Appreciate any thoughts. Thanks!
ENTRY AREA
PAD VIEW
