I have been searching on Amazon, all I have found has a converter/decoder included but no built in audioThere is a Dahua camera in 5 series with a HDMI out
The HDMI camera on Amazon is linked at the bottom of this post but has no buit-in microphone.I have been searching on Amazon, all I have found has a converter/decoder included but no built in audio
Sorry my use case is for a Church, they want the service to be able to be viewed and heard in the children's care section as wellThe HDMI camera on Amazon is linked at the bottom of this post but has no buit-in microphone.
You did not answer MY questions above in post #2 so I have no idea what you actually need.
LINOVISION HD1080P HDMI Security Camera with HDMI or VGA Output
I still have questions in order to provide a reasonably helpful reply:Sorry my use case is for a Church, they want the service to be able to be viewed and heard in the children's care section as well
answersI still have questions in order to provide a reasonably helpful reply:
1) What is the distance from the camera to the TV in the children's care section?2) Can cable of any type be installed from the camera to the TV in the children's care section?3) What kind of inputs does the TV in the children's care section have?4) Is the TV a "Smart TV" with Internet capability (Ethernet and/or Wi-Fi) ? What is the make/model?5) Do you have a budget?
I would buy a 4MP Dahua-OEM'ed Varifocal network camera with a 1/1.8" sensor and built-in mic such as this EmpireTech IPC-T54IR-ZE from @EMPIRETECANDYanswers
#1 50-70ft
#2 any should be okay preferably simple as possible as
#3 HDMI Ethernet other connections usb
#4 HiSense 65in QLED 4k fire tv not sure of model at the moment
#5 $400
Thank you will try thisI would buy a 4MP Dahua-OEM'ed Varifocal network camera with a 1/1.8" sensor and built-in mic such as this EmpireTech IPC-T54IR-ZE from @EMPIRETECANDY
Run CAT-6, 23 gauge, pure solid copper (no CCA), CMR (Riser) jacketed, Ethernet cable from camera to nursery
Back at the TV, power the camera with a POE injector that is UL-listed, grounded and wall mountable
At POE injector, plug camera into "POE", TV into "LAN".
Log into camera and assign static IP to TV of 192.168.1.200, camera should be already defaulted to IP of 192.168.1.108
A Fire TV should have a Silk browser onboard to play a RTSP stream from the camera. VLC for Fire should also work but is more complicated.
Create a shortcut (favorite) in browser to rtsp:/camera-username:camera-password@192.168.1.200:554/cam/realmonitor?channel=1&subtype=0
NOTE: put 2 "/" after "RTSP:" as forum won't display 2 consecutively here.![]()
Please note edited post #9 above, I had references to TV and camera incorrect/confusing.Thank you will try this
