CameraEvents Service - Dahua Events to mqtt
psycik
Dec 9, 2015
240
46
Wellington, New Zealand
As per: NodeJS Module: node-dahua-api
psyciknz/CameraEvents
This is a python service I run in docker. One of the first I wrote from scratch, so the documentation is probably a little light.
I've updated the readme for some run information, (git clone, python CameraEvents.py). And will figure out making the docker image automatically (this is all learning to me).
The main things it can do are to convert all VideoMotion events and IVS events into switches that can then be read by OpenHAB and HomeAssistant (or anything else that uses MQTT). IT also has the ability to pull a snapshot from the camera and post that as binary data to mqtt.
This is great. Full circle to ipcamtalk. The script I modified to work with MQTT originally came from the forum here!
Yeah there was a base I'd read, (and I believe I've kept the original credit). And adapted it. I had a similar service that was windows (c#), but most of my gear had moved to docker/python so I was keen to re-write it as I learnt python more.
Reactions: johnnyletrois
Thx for the info.
So..
I have to install node.js etc. as described here:
after that gitclone your python script and run it?
No mine is completely separate to the node-js.
Just git clone to a folder, and run.
I only added a comment there as I want working on a similar service in that it talked to the dahua api and that was the only thread that seemed to discuss the api.
Got it
The requirements in requiremnts.txt are needed?
paho-mqtt
pycurl
ConfigParser
requests
Thx again :highfive:
Hi,
some problems to run the script:
Code:
me@ubuntu18:~/CameraEvents$ python3 CameraEvents.py
Traceback (most recent call last):
File "CameraEvents.py", line 15, in <module>
import ConfigParser
ModuleNotFoundError: No module named 'ConfigParser'
me@ubuntu18:~/CameraEvents$ pip search ConfigParser
configparser (3.7.3)              - Updated configparser from Python 3.7 for Python 2.6+.
INSTALLED: 3.7.3 (latest)
Some Hint?
Best regards
p
Hi,
import ConfigParser
Some Hint?
Best regards
You're running in python (not docker?)
pip install ConfigParser
Same with everything else in that requriements.txt. I believe there's a command that will take the requirements.txt and go get everything it needed.
Thx.
I already intstalled ConfigParser with pip under ubuntu18.x
I tried various hints to solve ... No luck.
Is there a Docker Image available?
I think i get it to work.
Changed ConfigParser to configparser.
Edit my config.ini
Here my terminal output:
Code:
2019-02-26 21:13:23,523 - __main__ - INFO - Loading config
2019-02-26 21:13:23,524 - __main__ - ERROR - Error Reading channel list:No option 'channels' in section: 'Garten'
2019-02-26 21:13:23,599 - __main__ - DEBUG - Added Dahua device at: http://myIP/cgi-bin/eventManager.cgi?action=attach&codes=[VideoMotion,CrossLineDetection,AlarmLocal,VideoLoss,VideoBlind]
2019-02-26 21:13:23,601 - __main__ - INFO - Connected to MQTT OK Returned code=0
2019-02-26 21:13:23,806 - __main__ - DEBUG - [IPC]: HTTP/1.1 200 OK
Cache-Control: no-cache
Pragma: no-cache
Expires: Thu, 01 Dec 2099 16:00:00 GMT
Connection: Keep-Alive
Content-Type: multipart/x-mixed-replace; boundary=myboundary
2019-02-26 21:13:23,807 - __main__ - DEBUG - [IPC] OnConnect()
heartbeat
2019-02-26 21:14:13,798 - __main__ - DEBUG - Heartbeat
heartbeat
2019-02-26 21:15:03,997 - __main__ - DEBUG - Heartbeat
2019-02-26 21:15:44,746 - __main__ - DEBUG - [IPC]: -- myboundary
Content-Type: text/plain
Content-Length:44
Code=CrossLineDetection;action=Start;index=0
  File "CameraEvents.py", line 261, in OnReceive
    crossData = json.loads(Alarm["data"])
KeyError: 'data'
2019-02-26 21:15:44,798 - __main__ - DEBUG - [IPC] OnDisconnect(Failed writing body (0 != 108) (23))
2019-02-26 21:15:50,019 - __main__ - DEBUG - [IPC] OnDisconnect(Success)
heartbeat
2019-02-26 21:15:54,234 - __main__ - DEBUG - Heartbeat
2019-02-26 21:15:55,188 - __main__ - DEBUG - [IPC]: HTTP/1.1 200 OK
Pragma: no-cache
2019-02-26 21:15:55,188 - __main__ - DEBUG - [IPC] OnConnect()
2019-02-26 21:16:30,976 - __main__ - DEBUG - [IPC]: -- myboundary
Content-Length:44
KeyError: 'data'
2019-02-26 21:16:30,977 - __main__ - DEBUG - [IPC] OnDisconnect(Failed writing body (0 != 108) (23))
2019-02-26 21:16:36,248 - __main__ - DEBUG - [IPC] OnDisconnect(Success)
2019-02-26 21:16:41,468 - __main__ - DEBUG - [IPC]: HTTP/1.1 200 OK
Pragma: no-cache
2019-02-26 21:16:41,468 - __main__ - DEBUG - [IPC] OnConnect()
heartbeat
2019-02-26 21:16:44,430 - __main__ - DEBUG - Heartbeat
heartbeat
2019-02-26 21:17:34,626 - __main__ - DEBUG - Heartbeat
heartbeat
2019-02-26 21:18:24,817 - __main__ - DEBUG - Heartbeat
heartbeat
2019-02-26 21:19:15,008 - __main__ - DEBUG - Heartbeat
I get Heartbeats topics. But no Topics for IPC Events.
mmh
Hmm You don't get a json string with the CrossLineDetection?
Code:
Content-Length:905
Code=CrossLineDetection;action=Stop;index=0;data={
   "Class" : "Normal",
   "CountInGroup" : 1,
   "DetectLine" : [
      [ 3843, 5677 ],
      [ 6512, 5136 ]
   "Direction" : "LeftToRight",
   "EventSeq" : 11,
   "FrameSequence" : 41852,
   "GroupID" : 11,
   "IndexInGroup" : 0,
   "LocaleTime" : "2019-02-27 10:25:21",
   "Mark" : 0,
   "Name" : "Gate",
   "Object" : {
      "Action" : "Appear",
      "BoundingBox" : [ 3536, 5504, 4560, 8192 ],
      "Center" : [ 4048, 6848 ],
      "Confidence" : 0,
      "FrameSequence" : 0,
      "MainColor" : [ 0, 0, 0, 0 ],
      "ObjectID" : 1100,
      "ObjectType" : "Vehicle",
      "RelativeID" : 0,
      "Source" : 0.0,
      "Speed" : 0,
      "SpeedTypeInternal" : 0,
      "Text" : ""
   "PTS" : 42956392890.0,
   "RuleId" : 1,
   "Sequence" : 0,
   "Source" : 36137280.0,
   "Track" : null,
   "UTC" : 1551219919.0,
   "UTCMS" : 708
So mine does this...and this is what it's based on. I might have to add a check for that, and just trigger an event with no detail (just like a videomotion event)
Yeah ..looks like.
Code:
2019-02-26 21:59:50,727 - __main__ - DEBUG - Heartbeat
2019-02-26 22:00:21,396 - __main__ - DEBUG - [IPC]: -- myboundary
Content-Length:44
KeyError: 'data'
2019-02-26 22:00:21,447 - __main__ - DEBUG - [IPC] OnDisconnect(Failed writing body (0 != 108) (23))
I also didnt get a mqtt message that crossline detection happend.
what could I do to figure it out.
So this section
Code:
_LOGGER.info(Alarm["Code"] + " received: " + Alarm["data"] )
if "Direction" not in crossData:
direction = "unknown"
else:
direction = crossData["Direction"]
region = crossData["Name"]
object = crossData["Object"]["ObjectType"]
regionText = "{} With {} in {} direction for {} region".format(Alarm["Code"],object,direction,region)
self.client.publish(self.basetopic +"/IVS/" + Alarm["channel"] ,regionText)
you'll need to refactor....In fact if it was removed and bundled in to the VideoMotion code: (ie change line 245)
Code:
if Alarm["Code"] == "VideoMotion" or Alarm["Code"] ==  "CrossRegionDetection" or Alarm["Code"] ==  "CrossLineDetection":
then for your case you'd bypass the code causing the problem. But all MQTT events would say "motion detected" - but it should get you going.
Hi psycik.
This looks good :)
Code:
2019-02-26 22:24:05,505 - __main__ - DEBUG - Heartbeat
2019-02-26 22:24:08,064 - __main__ - DEBUG - [IPC]: -- myboundary
Content-Length:44
2019-02-26 22:24:08,065 - __main__ - INFO - Video Motion received: IPC Index: Garten Code: CrossLineDetection
2019-02-26 22:24:08,065 - __main__ - INFO - Snapshot Url: http://myIP/cgi-bin/snapshot.cgi?channel=1
2019-02-26 22:24:08,456 - __main__ - ERROR - Error sending image: Object of type 'bytes' is not JSON serializable
2019-02-26 22:24:10,425 - __main__ - DEBUG - [IPC]: -- myboundary
Content-Length:43
I change the code in Line 245 as you described.
Now first a play with this in my homeautomation. :love:
it seems to not be getting an image. I assume this might be related to that last change I had to make (listed in the readme, that for my specific NVR I have to put channel (index)+1. So for a snapshot if it's index=0 (as per your example) I have to ask the NVR for channel=1. Yours is probably channel=index not index+1
So if you look at the snapshot request (new thread snapshot), you should see it asking for index+1 you should be good to remove the +1
Your right. But i look at that later.
First I have to Bridge my "CameraEvents MQTT Broker" (local Broker just for your CameraEvents Script) to my main Broker.
My main Broker needs user credentials :wave:
Best regards and have a nice day!
DO
First I have to Bridge my "CameraEvents MQTT" (local Broker just for your CameraEvents Script) to my main Broker.
Do you want to post your version to me, and I'll look at putting some of those changes in and dealing with the change in API (the 1/0 thing)
I should also make "do you want an image" configurable for if you're not using that function, they're pretty large to be chucking around mqtt for no reason.
