Yes, please read above postsIs it possible to enable it for nvr recording?
Maybe the camera does not generate ONVIF event notifications. Not all do.the Trigger Area does not start the recoding!
what mobile app does it use?Could someone please explain how to use this file "ceshi.ini" to enable ONVIF, if I'm not going to upgarde the firmware?
Coz i've been contacting the technical support team to get the firmware upgrade with no reply.
I can use them in Home Assistant, with ONVIF integration.this show up when I access to 8899 port
I think this one actually support ONVIF, but got remove or restrict somehow
ENVU-Boot 2013.10.0-AK_V2.0.03 (Oct 19 2021 - 20:05:22)
DRAM: 64 MiB
anyka spi flash. bus_width:1
8 MiB
mmc_initialize: ak_sdhsmmc_init OK!
ANYKA SDHC/MMC4.0: 0
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
load_addr = 0x81808000!
Net: AKEthernet-0
baudrate=115200
boot_normal=run read_kernel; bootm ${loadaddr}
bootargs=console=ttySAK0,115200n8 root=/dev/mtdblock4 rootfstype=squashfs init=/ sbin/init mem=64M memsize=64M mtdparts=spi0.0:384K@0K(boot),64K@384K(ENV),64K@44 8K(MAC),1536K@512K(KERNEL),1024K@2048K(ROOT),4608K@3072K(USR.SQUASH),512K@7680K( USR.JFFS2)
bootcmd=run boot_normal
bootdelay=3
erase_env=sf probe 0:0 ${sf_hz} 0; sf erase 0x20000 0x2000
ethact=AKEthernet-0
ethaddr=00:55:7b:b5:7d:f7
fs_addr=0x370000
init=/sbin/init
ipaddr=192.168.1.99
kernel_addr=0x80000
kernel_size=0x200000
loadaddr=0x81808000
memsize=64M
mtd_root=/dev/mtdblock4
netmask=255.255.255.0
read_kernel=sf probe 0:0 ${sf_hz} 0; sf read ${loadaddr} ${kernel_addr} ${kernel _size}
rootfstype=squashfs
serverip=192.168.1.10
setcmd=setenv bootargs console=${console} root=${mtd_root} rootfstype=${rootfsty pe} init=${init} mem=${memsize}
sf_hz=20000000
stderr=serial
stdin=serial
stdout=serial
update_flag=0
ver=U-Boot 2013.10.0-AK_V2.0.03 (Oct 19 2021 - 20:05:22)
vram=12M
glad to help
I also found out that "the upgrade file" to enable ONVIF turn out to be this simple ceshi.ini where you can edit manually with notepad
and if you want to upgrade firmware manually you can also give the support a buzz at v380technical@gmail.com
I solved the RTSP auto disconnect problem mentioned above by upgrading fw
About firmware: If you have the same camera as I do, you can use the below firmware.
After that you can upgrade to v2.5.10.6 using the mobile app, then the ceshi.ini file to enable ONVIF.
Your camera will work well with ONVIF / RTSP, no more connect - disconnect - connect issue
Just be sure that you get the same camera as mine by looking at the hardware inside and comparing the info
About the wifi: I think it s hardware issue, not firmware related
Check if the antenna wire is connect properly to the board (use a VOM to check continuity). You should record the disassembly process for later reference
If the antenna wire is fine, try another antenna.
I mounted my camera on really high spot and used LAN connection. So I cannot help you checking the wifi signal reception
Goodluck
Hi, it's seems to me that I have the same device.Hi!
I want to create a new topic, but I don't know how, sorry.
I have this problem:
I bought a cheap Chinese v380 camera for testing.
The manufacturer is not specified.
This camera only worked with v380 App, but and I need to add it to my PC surveillance station.
With the help of ceshi.ini I was able to open additional ports and now there are four of them: 554; 8890; 8800; 9800
After that, I received a video stream from a link like this: rtsp:/192.168.1.xxx/live/ch00_1
(ONVIF Device Manager v2.2.250 saw this camera, but not completely. Some items do not work)
