Any recommendation on appropriate hangers for cat cable, ( Im using CAT6)?
I'm talking about like along long spans of floor joists in my unfinished basement for example.
I have been uing the plastic coated U shaped nails every 5 ft or so which will hold 2 or 3 cables max at a time, leaving just enough space so the wires are not crimped but wont move or fall.
...well , now I ll be running probably 8 more along most of the same route and I have one hung that has failed that needs to be removed, so now I have to pull it all down and start over.
Short sited on my part.
Is there a decent hanger option that I could run, say 5-10 through at a time that would allow easy addition or removal if one goes bad without taking all the hangers down and restringing?
Iv seen some plastic loop hangers but they are pretty small, usually for a single cable.
