fenderman
Staff member
- Mar 9, 2014
- 36,891
- 21,419
That's just user errorEither way, it can't be any worse than the P-O-S Hikvision turret I bought months ago. Still can't get the piece of crap working
I looked to see if you'd posted about that but didn't find anything.the P-O-S Hikvision turret I bought months ago. Still can't get the piece of crap working
alastairstevenson said:I looked to see if you'd posted about that but didn't find anything.
What's the camera model, and what type of problem is it?
Probably we can help.
That suggests it's a bullet, as opposed to a turret, which usually don't have a reset button.I've even tried doing a hard reset, then repeating all the above, all to no avail
OK, so the PoE is working.I'm at a loss as to what to try next but any suggestions would be very appreciated
alastairstevenson said:I should have asked what the model number is on the label.
Does the switch link detect LED come on?
Where in the UK are you? I could check it out just for fun.
3 MP Ultra-Low Light Network Turret CameraIts model number is : DS 2CD2335FWD.1 4mm
Ah, yes, I'd forgotten about the SD-card variant and the reset button under the hatch.The reset button (very small) is under an IP-sealed cover, held on by 2 screws (I think there's also a micro Sd-cad slot in there too)
That's a pretty good low-light camera, I have the same model, runs in colour 24x7.Its model number is : DS 2CD2335FWD.1 4mm
Let's do that - I get a bit bored when there are no problems to solve, and I'm fairly familiar with the consumer Hikvision models.I'm between Manchester & Huddersfield, - thank you for the kind offer (happy to pay), so could send it you via post if you fancy a head banging exercise
Definitely worth trying, easy enough to test - though I've never (so far ...) seen SADP fail to find a Hikvision device on a different IP address range than the PC its running on.Is there a chance the previous owner's network was in the 10.x.x.x range and yours is in the 192.168.x.x range? That might be contributing to your inability to find it.
On testing, the camera worked OK when powered by external 12v, no problems seen.So what was the problem and the cure?
On connection to a PoE switch, power was requested and supplied, the IR LEDs came on, the link detect light came on and flashed a lot - but zero traffic over the network. So not working over PoE.
On connection to a Hikvision NVR PoE port, power was requested and supplied, but no link detect showed.
When opening the case, I noticed that the connector in to the PoE board from the inbound ethernet cable was not fully home, it was at a slight angle.
Pushing it fully home, the camera worked normally.
Lifting one side slightly, to the same position it originally was, gave the same symptoms as originally seen, including the flashing link detect LED, but zero network traffic.
This was repeatable.
So arguably a manufacturing assembly fault.
There is nothing fancy at all to deduce this - hope you're not disappointed -Could you please share what tools you are using and what to watch for to determine:
"power was requested and supplied"
FSM7326P) #show poe port 0/13
Admin Output Output Output
Intf Mode Class Priority Power Current Voltage Limit Status
(W) (mA) (volt) (W)
0.13 Enable 2 Low 3.486 70 49 18 Delivering Power
(FSM7326P) #
If it's the 5MP S500 with the IMX178 - I had one in use for over 3 years which started playing up a couple of months back.Sure would have been nice if my piece-of-crap Longse camera had been so simple to fix a few years ago.
Yup, it was the S500. Except it would go offline and come back online intermittently. Very first thing I did was unplug and reseat all the internal cables I could, and it still keptIf it's the 5MP S500 with the IMX178 - I had one in use for over 3 years which started playing up a couple of months back.
The video would stop when the IR LEDs came on.
I swapped it out for an IMX307 low-light camera and had a look at it.
The in-cable PoE adaptor was 'hunting' under the load of the dual EXIR IR LEDs, which were drawing an unusually high 6w - 7w of power.
One of the reservoir capacitors had gone high ESR / reduced capacitance.
I replaced the cable with a new powered cable bought off Aliexpress and the camera is back working.
It's sitting in a box - it will probably go on eBay.
ing. If I had seen any leaking/bulging caps, I might have replaced them. Didn't even consider high ESR at the time.
