With respect, neither do we when you have supplied almost zero information about the devices you have the problem with.not sure what to do
No shit Sherlock. If "google for fixes" was your standard answer there would be no need for forums. Was hoping someone here had the same problem and new the simple fix. Either way im sure i will sort it and once i do i could either let people know on the forum for future reference or just leave it to be googled.He pointed you to google for fixes.
Well, I thought it was a useful response to see what a search could come up with as I hadn't experienced that specific response myself, and you still hadn't provided even basic info such as model numbers, the origin and status of the camera and so on.No shit Sherlock. If "google for fixes" was your standard answer there would be no need for forums.
which had the ring of truth. Which was why I responded with my suggestion."Config Error 18" means that a camera needs to be initialised before it can be used on the NVR. To initialise a camera you will need a laptop with Config Tool and either a PoE switch or a 12V power supply. Connect a laptop to the switch the camera is connected to and open Config Tool.
You need to look at your original post, you didn’t even post the model of the cam or the NVR so how exactly were you expecting people to help you?
It’s no use posting “it’s broke, doesn’t work, please help” as unfortunately the read your mind forum plugin hasn’t worked ever since I joined the forums.
