I've been searching in this forum to try to determine what the requirements are for configuring with a web browser currently and have not been able to determine that completely, hence this new topic.
My need is to set up motion detection in a camera I just purchased from Andy, a IPC-HDBW5441F-AS-E2. When I say "config the camera" below, the one thing I really need is to set up motion detection. I can access live video with an RTSP stream if needed but I see no way to config motion detection without a working browser interface. I do not have an NVR. I have my cameras write files to an FTP server.
I have found that my usual method of configuring, with an old (52.9.0) version of Firefox with MMX does not work with this new camera. I have older Dahua cameras that I configure with this old Firefox. I get a prompt to allow MMX when I log into the web interface of those cameras and after accepting, the live video works as well as the motion config.
When I access the new camera with the old Firefox, I do not get the MMX prompt as it seems the newer camera software no longer has that function. I get a link to download a plug-in which is a link to a file on the camera that is an exe file: webplugin.exe. It is 4852529 bytes long.
When I try to use a current Chrome to access the new camera, the plug-in link takes me to the NACL plug-in page on the google web store. There is a message on that page about chrome apps not being supported and it cannot be added to chrome.
I've found some threads that mention an IE plugin for chrome. I found "IE Tab" but it a) requires a paid license after 2 weeks, and b) requires an executable to be installed and run. I prefer to avoid this solution.
I've found some threads stating that it is best to stay with IE if running on Windows. I did find these very helpful instructions from @wittaj on how to make IE run on current Windows:
I am able to run IE using this VB script but when I access the new camera with IE, it also presents me with the link to download a plug-in. The plug-in exe file that is downloaded is the same one that is downloaded using the link when accessing using the old Firefox.
Questions:
1. Is there a way to config this newer camera with current Chrome, using a plug-on or any other means?
2. Is there a way to get this new camera to use the MMX plug-in (allowing me to use my old Firefox to configure it)?
3. Is there a way to config this newer camera with IE without installing the plug-in exe file from the camera?
4. If the plug-in is required or the best option, is it generally considered safe to install and use?
Thanks
While newer cameras are supposed to work with other browsers and not need the plug-in nonsense, keep in mind to ensure full compatibility, IE is still preferred. And this isn't specific to just Dahua either. And sometimes the plug-in nonsense is needed.
It comes down to IE was the most popular browser when these cameras started to be made, so they centered the firmware around one particular browser and they got lazy and never updated the internals of the program to play nice with other browsers as more became available and IE started to fade.
Back when the firmware was written, it was...
Questions:
Thanks
