CPAI Object Detection
Dorsey Pender
Sep 7, 2019
217
30
San Francisco
Where is it getting the list of objects to detect? I am getting also a lot of No Objects Found. I am on the latest CPAI and BI.
I do not have bottle or train as an object that I want it to look for. I do not have custom models selected in AI. Under To Confirm I have person,bicycle,car,motorcycle,bus,truck,bird,cat,dog
08:06:07:Response rec'd from Object Detection (YOLOv5 .NET) command 'detect' (...b861d9) ['No objects found'] took 518ms
08:06:11:Response rec'd from Object Detection (YOLOv5 .NET) command 'detect' (...3e366c) ['Found bottle, bicycle'] took 137ms
08:06:22:Response rec'd from Object Detection (YOLOv5 .NET) command 'detect' (...daffc6) ['No objects found'] took 170ms
08:07:43:Response rec'd from Object Detection (YOLOv5 .NET) command 'detect' (...220022) ['Found train'] took 159ms
First question is what objects are you wanting to detect? Do you want the same objects to be detected on all cameras. You can check the 'Alert" tab setting on each camera and click on the "AI Configuration" and see if the "Static object analysis" is checked, if so try unchecking it!
