fenderman
Staff member
- Mar 9, 2014
- 36,891
- 21,419
Yes, try going direct to the 3 drives. Setup aux folders and split the load.Ok. I’m currently recording directly to the solid state OS drive, then sending to a WD Purple. Is it ok to go direct to the WD Purple and cut out a step?
I have three8tb WD Purple drives. I’ll split the cameras between them tomorrow.
The ram seems to hover 8-12gb usage. I have 16gb total. Should I upgrade to 32gb with this many cameras?
yes, you might want to try more memory despite it appearing that you are not using all.
Blue iris and CPU consumption as it relates to memory usage
