CPU usage
Defender574
Nov 11, 2024
75
43
I currently have a 14700k & 5080 that runs BI and is also used for gaming. I would like to upgrade to AMD for the gaming performance and wondered if a 9800x3d would be effected gaming while running BI or if I would need to get something like the 9950x3d with duals CCD's.
All of my AI is done via the cameras.
While BI doesn't require a lot of CPU power to function, I would highly recommend that you break out the BI functionality to its own system. A used SFF computer is generally what has been suggested here before. Companies regularly unload these machines in bulk and they turn up on the used markets. It is cheap, but also has enough room for several HDs, etc. Of course I haven't looked at recent prices now that AI is causing prices to go through the roof on some items.
Reactions: ARAMP1
Agreed. Keep your cams on their own dedicated PC. That's basic security there. I take it a step further, my BI PC and all cams are on their own network (vlan) isolated from everything else on the network.
I ran a old Dell 5050MT with i7 6700 and 16gb ram for years with very little load on it. It was also a power efficient system. Something like that should be readily available on fleabay for not much money.
Would you run email or a web browser or gaming on an NVR? The answer is NO.
That is the way I look at my BI/PC combo - it has one function. And a refurb was way less than an NVR.
Reactions: scoob8000
