Custom Alarm Audio
Kevin Doe
Jan 24, 2021
126
107
Ohio, USA
Looking to upload a customized audio file for the alarm, when IVS rules are triggered. Looks like I can add the audio file here:
I keep getting file too large when I attempt to upload the file. The manual says it can take .pcm or .wav2 formats. I tried a regular .wav at ~2069 KB, and then tried converting it to a .pcm and the file was 1032 KB, and also got a too large warning. Anyone know what size will work? I'm only trying to upload a ~10 second audio clip.
Audio clip for those interested, LOL
Reactions: sebastiantombs
Yeah I had that problem as well. They don't have a lot of storage on these things so it doesn't take much to be too large.
You could try deleting some of the ones that came with the cam and see if it clears enough space.
I was able to get a 20 second .wav file at 3.2MB on it.
In the attached screen shot in my first post, you can see that the delete button is greyed out. That was my first thought as well, but it doesn't look like I can.
Bummer. Let me go pull mine up now. It was another camera that I uploaded the .wav file to.
Yep, I thought I was able to delete from my older camera, but now I remember that it came without the audio files, so I had to upload them and only did the ones that I wanted.
I did find that sampling should be 8K 16bit, less than 1MB for newer cams, so try that.
Any idea how to convert the audio file I linked to, to the specs you mentioned and stay under 1MB? I found an online audio converter, but no matter what options I try, the final audio file size ends up larger than the original one that's at 2.07 MB.
I ended up recording it to my phone with an app like you said (but on my iPhone).
The recording was done with the following specs:
.wav format
44.1 kHz sample rate
128kbps bit rate
Mono
The file size is 891KB. When I upload, it says "bad file format". Tried to change to a .pcm, and got the same warning.
I tried an online converter to convert to a different sample rate wav file, but the file size ends up way larger. Here is the specs I tired to convert to:
.wav
8k sample rate
128kbps bit rate
Mono
16 bit
File size ended up as ~14MB.
After playing with it some more, I found out that I can record an audio successfully. Hooked up a nice pro audio mid to my PC, and played the clip over the speakers, while recording on the Camera's interface. Playback yielded nothing. Then I had the idea that maybe the "record" option was to record from the camera's mic. I was correct. I put my phone playing music by the cam, and hit record for 10 seconds. It worked. When I played back the audio over the camera I heard the music playing. Only downside is that I'll need a second person to press the record/stop button, while I'm standing by each camera playing the audio clip. And the quality is really bad. I need to figure out how to get a .wav file to upload properly.
Anyone have any good ideas for a custom message?
I've used GLaDOS "thank you for taking part in this facial recognition experiment, your face has been saved" on my front door camera for a few years now.
Here's some others I've made & used.
Google AI Text to Speech cloud console test demo is GREAT.
It allows you to demo the various voices. Just use OBS to do audio capture recording.
The AI TTS from Google allows you to input a prompt about tone, speed and 'aggression' of the text narration.
Scroll down a little to the demo section:
  • Haha
Reactions: Arjun
Does any one have any convincing .wav files that sounds like something that would be used in National Defense or 2001: Space Odyssey?
