Dahua almost bootloop! DH-XVR5116H-4KL-X
Mar 11, 2020
11
Europe
Hi, I have a Dahua XVR DH-XVR5116H-4KL-X . This device has a boot loop problem, but when I hold the reset key and then turn it on, the device boots!
The device has two HI3531 V100 CPUs.
The next problem is that the device doesn't get a lot of common commands like "help" and "printenv". I tried to update the device through UART and the latest firmware version. Using the following codes,
Code:
setenv ipaddr 192.168.1.108
setenv serverip 192.168.1.128
setenv gatewayip 192.168.1.1
saveenv
I was finally able to establish a TFTP connection and updated the device with the "run up" code. During the update, no errors were observed, but the device did not rise again after the update, and the previous situation continued. But the status of the device has not changed!
I'm putting the UART log here.
Code:
System startup
U-Boot 2010.06-svn4554 (May 13 2024 - 21:26:29)
Check Flash Memory Controller v100 ... Found
SPI Nand total size: 128MB
DPLL:466Mhz DDR:1864Mhz
APLL:1400Mhz VPLL0:297Mhz
Dectected gmac0 phyaddr set to 0, is it right?
nice find PHY TRL8211 on higmac
ETH0: PHY(phyaddr=0, rgmii) link UP: DUPLEX=FULL : SPEED=100M
mcu i2c fail
mem= 570
slave mem size= 218
Config/hwidconfig not found!
Hit any key to stop autoboot:  0
hisilicon # *****
Unknown command '*****' - try 'help'
hisilicon # help
hisilicon # printenv
Unknown command 'printenv' - try 'help'
hisilicon # version
hisilicon # help
hisilicon #
System startup
U-Boot 2010.06-svn3930 (May 10 2019 - 21:20:16)
*** Warning - bad CRC or NAND, using default environment
OK
OK
System startup
mcu i2c fail
mem= 570
slave mem size= 218
0 Storage Device(s) found
stMaxRect.u32Width:1024, stMaxRect.u32Height:768.
HDMI_INFO:Hdmi_PixelFreqSearch[127] ,u32Fmt6.
TFTP from server
Downloading: T T T
Retry count exceeded; starting again
   Loading Kernel Image ... OK
OK
Starting kernel ...
System startup
OK
OK
System startup
mcu i2c fail
mem= 570
slave mem size= 218
TFTP from server
Downloading: T T T
OK
Starting kernel ...
System startup
OK
OK
System startup
mcu i2c fail
mem= 570
slave mem size= 218
TFTP from server
Downloading: T T T
OK
Starting kernel ...
I'm more likely to have a software problem because every time I I'll keep the reset key, the device boots.
Hello to people who are likely to encounter this problem in the future.
The solution is:
I updated the device with another version of the firmware and the device problem was solved.
So if you're having the same problem, Be sure to try different versions for the update.
