Dahua Combo Wireless/Wired IP question
hdtvjeff
Nov 19, 2014
218
19
Hi
On a combo wired/ wirless Dahua cam Do I need 2 different IP addresses setup in port forwarding?
On the dahua setup page, it seems I can't use the same 192.168.1.25 twice for wired and wireless without triggering a conflict.
Port forwarding is already setup correctly and the camera transmits correctly.
I guess what I am asking if I switch over to wired do I have to change wired to a new local IP and then change port fow in router?
Thanks !
Hi
Thanks !
Step 1, never port forward any camera
step 2, see step 1
that said, you will only be connecting to the network with one or the other....not both...you dont have to change the port, just the camera ip address..
I feel uneducated now, going back to Panasonic IP cameras 10 years ago and with every dahua I did not know these cameras could be accessed remotely without port forwarding using a static IP
Time to go back to school !
Just didn't know you can remotely access a camera without it being port forwarded
yep.. just get a netgear or asus router with VPN built in... super simple to set up... way easier than I though it was going to be....
So VPN plus port forwarding or VPN alone?
no need to port forward if you are using a VPN..... it acts as you are connecting from your home connection, while out on the road..... I use it with the netgear nighthawk R8000. but others use it with some ASUS models...
Thank you for the enlightenment !
I guess what you and the real pros here are saying is that a VPN is safer than port forwarding.
Reactions: aristobrat
I was a young grasshopper once...
and yes.... don't ever port fwd... its bad.... VPN is def the way to go.
I have a 16 port gigabit unmanaged switch which many of my dahua connect to, does that have to be upgraded to a VPN variant too?
Thank you,
Jeff
Thank you,
Jeff
nope.. just get a new router (if ur current router doesnt support VPN)
ur switch is fine
Reactions: hdtvjeff
Also make sure UPNP is disabled in the cameras and router otherwise it will likely create port forwarders without you knowing.
Reactions: hdtvjeff
