- Mar 9, 2014
- 36,891
- 21,419
I have had the Dahua IPC-HDB3200C in operation at a location for about a year with blue iris. It worked well, except that if local recording to the internal SD card was enabled there would be ghosting in the stream. Each time a person walked by the movement was blurred and ghosted. This only occurred when sd card recording was enabled. After much testing, i discovered that if i changed the recording format from the default h.264 to h.264B there was no longer any ghosting. Hope this helps someone.
