I check the total work time on this cam, 62 days, 13 hours.
My question is on the PTZ function. I thought it was spot on after setting up my presets with hot zones in the home preset in BI, but it's not. It does not go back to that same spot I preset, close, but no cigar and I believe it did better at first, not sure now.
Are you guys getting prefect placement on your presets? Or am I asking to much from the cam? Or is there something wrong with it? I question if it ever was prefect.
One thing for sure, it will not move and then jump when I put it in the home preset. Far as I know, it only jumps around in that one spot or area only. What I mean my jumps around, I'll hold the arrow button down continuely to move the camera and it will not move for a few nano seconds and then take off bat out of hell. Or I'll mouse click the arrow button one at a time and nothing happens, so I continue to click one at a time, then after 3-4 clicks, it moves a bunch, like it catching up. It's like that both UP and Down, like a bad spot in whatever moves it.
Things I've tried. Check level of the cam, was not perfect, now it is and still the same issue. I've restarted the PTZ in the camera itself using a browser and nothing has changed
System version: 2.800.0000009.3R, Build Date: 2020-03-31
So whats all your take on this? suggestions?
