CCTVCam
- Sep 25, 2017
- 3,178
- 4,124
I know exactly how it works and you are making a bunch of amateur newbie mistakes...long winded manefesto type responses does not prove your point. In the real world the difference between bitrate settings is negligible...and I cannot stress this enough, you can pick up a number plate no problem with 1024 bitrate...but keep reading the articles which provide no data or reference points...Not sure about your reference to doubling the bitrate - I never mentioned anything regarding that....here is a suggestion, buy an ip camera - any ip camera and test it....you are making lots of newbie assumption..the blurring seen in video has ZERO to do with bitrate and everything to do with the sensor and exposure....do yourself a huge favor and read the LPR section of this forum. I further suggest that you get some more experience under your belt before you mislead folks about proper bitrates and ip cameras. You are not the first newbie to post nonsense like this without even owning a damn camera - i dont get it.
In that case the UK Government's experts at the Home Office who are advising Local Authorities and Police forces on compression must be a bunch of newbies:
Their video on bandwidth and compression, specifically at:1 min 29 secs, "the amount of compression we need depends to a large extent on the nature of the scene and the amount of movement within it ...."
Also, on compression generally, an explanation of compression, I frames, P frames, B frames and GOV / GOP - this one from the experts at Aixs CCTV systems:
