DH_NVR5XXX-4KS2_MultiLang_V4.001.0000003.1.R.200813
EMPIRETECANDY
IPCT Vendor
Nov 8, 2016
9,693
28,557
HONGKONG
Hey guys,
The latest new fimware has been released, this is the best version that we have now for the 5 series.
As we tested on the 2017 devices(NVR5216-16P-4KS2), @TechBill also test on his 2017 V1 device, working great too.
For the V2 version, @Wildcat_1 also tested, good to go. So we decicde to release the firmware now.
Attention: We don't undertake any risk that brick the NVR, we just tested on the 2017 device, the earlier devices we haven't tested.
Updated details, please check the attached file.
Support List
NVR5232-4KS2,
NVR5208-4KS2,
NVR5216-4KS2,
NVR5232-8P-4KS2,
NVR5208-8P-4KS2,
NVR5216-8P-4KS2,
NVR5216-16P-4KS2,
NVR5232-16P-4KS2,
NVR5416-4KS2,
NVR5432-4KS2,
NVR5464-4KS2,
NVR5416-16P-4KS2,
NVR5432-16P-4KS2,
NVR5464-16P-4KS2,
NVR5832-4KS2,
NVR5864-4KS2,
NVR5816-16P-4KS2,
NVR5832-16P-4KS2,
NVR5864-16P-4KS2,
NVR5424-24P-4KS2,
NVR5224-24P-4KS2,
NVR5232-4KS2(V2.0), Amazon.com : EmpireTech NVR5232-4KS2 32Channel 1U 4K&H.265 Pro Network Video Recorder English Version
NVR5208-4KS2(V2.0), Amazon.com : EmpireTech NVR5208-4KS2 8 Channel 1U 4K&H.265 Pro None POE Version Network Video Recorder English Version
NVR5216-4KS2(V2.0), Amazon.com : EmpireTech NVR5216-4KS2 16 Channel 1U 4K&H.265 None POE Version Pro Network Video Recorder English Version
NVR5208-8P-4KS2(V2.0),
NVR5216-8P-4KS2(V2.0),
NVR5232-8P-4KS2(V2.0),
NVR5216-16P-4KS2E, Amazon.com : EmpireTech NVR5216-16P-4KS2E 16Channel 1U 16PoE 4K&H.265 Pro Network Video Recorder English Version
NVR5232-16P-4KS2E,
NVR5224-24P-4KS2E,
NVR5416-4KS2(V2.0),
NVR5432-4KS2(V2.0),
NVR5464-4KS2(V2.0),
NVR5416-16P-4KS2E,
NVR5432-16P-4KS2E,
NVR5464-16P-4KS2E,
NVR5424-24P-4KS2E,
NVR5216-8P-4KS2E,
NVR5208-8P-4KS2E
Andy
As i know there has another version is on testing now, will be released later this month or early July.
Reactions: redfive
Andy, do you think it would be a good idea to create a thread addressing bugs found? Maybe It would help the engineers narrow down issues?
The only little bug I have seen so far in this new firmware is that the 8 ePoe ports report poor link quality when in fact previous firmware reported good.
NVR5216-16P-4KS2E
Use the same thread to report bug .. It what i do.
In this version, ptz control with imou works correctly, in version 4.001.0000000.1.R.200319 the camera (SD59225U-HNI) was spinning non-stop
So this new firmware, your NVR is back to normal now right?
Working okay here. Not sure if it's related but my notifications are seemingly are delayed by up to a minute?
After updating my NVR5216-4KS2, to this version and updating my IPC-HDW5231R-Z cams with DH_IPC-HX5X3X-Rhea_MultiLang_PN_Stream3_V2.800.0000015.0.R.200430 I have noticed that I am getting no email alerts for IVS tripwire crosses from the NVR like I used to. I AM however getting motion detection emails from my IPC-C35 cameras. I seem to remember the NVR had some areas for IVS previously but I am not seeing it in the new interface and think this is likely the issue. Is this the case and was this feature dropped? Or would this be a camera firmware issue?
Wow, had missed that section. Thanks! Good to know it is there. That said there is nothing here about enabling a screenshot email send on IVS tripwire rule cross event. Am I missing something here? It isn't even clear where the setting is to allow the motion detect on my IPC-C35s to trigger an email with screenshot, but it is working.
I’m not sure but look under network>email
Update: Yes it’s there. Turn on attachment
Is anyone else having problems with email alerts with this firmware? I cant seem to get Gmail working. When I configure it and hit the TEST button under Network>Email, it always falis. Tried using both SSL and TLS.
Also tried a spectrum email and it passed the TEST but still doesn't actually send event email.
Does anybody know how to use fast playback (2x, 4x, etc.) on the web interface? The manual shows a slider for this, but it's the audio volume slider that's where the playback speed slider is supposed to be.
After upgrading to this version the config tool no longer finds the NVR. Is anybody else seeing this, or know how to fix it?
Just before (on its left side) the audio volume slider , there is a double arrow (Fast)
Wish it was that easy. Not there on mine:
The double arrow is there with the hardwired monitor, not on the web interface.
