P psycik Getting the hang of it Dec 9, 2015 240 47 Wellington, New Zealand Dec 26, 2025 #1 Tried a reboot, tried the normal trick of remove them from phone and re-enable but no joy. Anyone else?
P psycik Getting the hang of it Dec 9, 2015 240 47 Wellington, New Zealand Dec 26, 2025 #4 Dammit. Annoyed mine have stopped. Unless the ip/ports have changed. As I do block those. But was working till 24th at 17:39 (nzdt)
W Wallop n3wb Feb 21, 2025 24 15 New Zealand Dec 26, 2025 #5 Mine has missed a beat since I installed the cameras. What isp are you using, I’m with Starlink.
wittaj IPCT Contributor Apr 28, 2019 34,534 65,749 USA Dec 26, 2025 #6 We also see this when the Dahua servers are down and thus cant make the initial P2P connection. But there are multiple server locations down and your region may be down while others are not. Reactions: bigredfish
bigredfish IPCT+ Member Sep 5, 2016 39,401 87,482 The Swamp Dec 26, 2025 #7 wittaj said: We also see this when the Dahua servers are down and thus cant make the initial P2P connection. But there are multiple server locations down and your region may be down while others are not. Click to expand... Now that you mention it, Dahua uses a lot of servers at AWS, which had serious issues on and off during the Holiday. Mine contacts a server in Canada go figure
