K KietV n3wb Jul 15, 2020 11 1 Houston Mar 16, 2024 #1 I bought NVR, IP cams from EmpireTech Andy. Now I need help setting up DMSS I can’t figure out. live view on the app seems to work only when I’m connected to the network. Even then, at times it will say connection failed.
K KietV n3wb Jul 15, 2020 11 1 Houston Mar 16, 2024 #4 Now DMSS says login timeout again and it won’t connect when I’m not connected to network. This is garbage?!
wittaj IPCT Contributor Apr 28, 2019 34,525 65,732 USA Mar 16, 2024 #5 How have you set it up - port forwarding or P2P via scan a QR code?
K KietV n3wb Jul 15, 2020 11 1 Houston Mar 16, 2024 #6 wittaj said: How have you set it up - port forwarding or P2P via scan a QR code? Click to expand... I did the online search option on the app
