Does anyone know how to find the second stream on the X-Spans Series?
cmx
Nov 9, 2024
121
51
NJ
I have a X-Spans Series camera it has a PTZ and a 180 degree camera. Does anyone know how to find the URL of both streams for BI? I can only find one.
Thanks!
If Dahua sourced, URL should be:
rtsp:/<username>:<password>@<ip_address>:<rtsp_port>/cam/realmonitor?channel=<channel_number>&subtype=<stream_type>
where port = 554, channel = 1, subtype = 0 for main stream and 1 = for sub stream
Examples:
With authentication, main stream
rtsp:/:password@192.168.1.108:554/cam/realmonitor?channel=1&subtype=0
Without authentication, sub stream:
rtsp:/192.168.1.108:554/cam/realmonitor?channel=1&subtype=1
NOTES:
1) Be sure to place 2 "/" after "rtsp:" as forum won't allow 2 to be displayed consecutively
2) In Camera's webGUI, insure streams are enabled and configured as required.
Reactions: cmx
Examples:
NOTES:
Thanks i will give that a try.
I got it to work with BI very easy.
I did discover one bad thing about the X-Spans Series, the top 180 cam does not have up/down adjustment like a 180 turret would.
Reactions: TonyR
I had it working rebooted my PC now i can only see one stream.
I don't get why stream profiles - main now says default before it had both main stream channels as a option.
