S sofducas n3wb Oct 31, 2017 4 1 Nov 3, 2017 #1 Everything is in the title!.... I found out an article on how to unbrick a AVTECH DVR... but nothing on AVTECH cam. The procedure must be similar...
alastairstevenson Staff member Oct 28, 2014 16,498 7,260 Scotland Nov 3, 2017 #2 Connect up to the serial console to figure out what the problem, therefore the solution, is. It's a standard feature on embedded Linux devices.
S sofducas n3wb Oct 31, 2017 4 1 Nov 3, 2017 #3 thanks for the info. is the one that you recommanded "PL2303HX-based serial TTL to USB convertor" would fit most of current cams?
alastairstevenson Staff member Oct 28, 2014 16,498 7,260 Scotland Nov 3, 2017 #4 sofducas said: thanks for the info. is the one that you recommanded "PL2303HX-based serial TTL to USB convertor" would fit most of current cams? Click to expand... Certainly that's worked well for me on quite a variety of devices - though I have fried a couple of them figuring out which pads/connectors are the serial console. That's the hard bit.
