- Jul 4, 2015
- 32
- 4
So i am planning on getting a driveway sensor that detects when a car drives over the sensor. The receiver unit has a relay (NO or NC) output and 12VDC connections that trigger when a car activated the sensor (see attached picture). I want use this relay to trigger a camera in BI so that i receive a notification and it starts to record.
I was trying to figure out if i could use a shelly 1 plus to monitor the relay and when the relay closes it would send and http requests ( http://[BIServerIP]:[Port]/admin?trigger&camera=[ShortCamName]&user=[BIUserName]&pw=[BIPassword] ) to trigger the camera.
I am not sure if this is possible with the shelly or how to go about setting it up. I am also open to any other suggestions on how to trigger BI via the driveway sensor relay that may be easier.
