DS-2CD2386G2-ISU/SL - Poe wiring diagram?
LoneEdge
Oct 1, 2019
39
16
United Kingdom
Hello all, I have a DS-2CD2386G2-ISU/SL which is in overall good contion and hasn't had much use but some of the pins on the POE connector was bent I tried to fixed them but no luck. I have seen on Youtube about repiaring a camera by cutting off the POE connector on the camera and soldering CAT5.
The video I seen is over 6 years old so wasn't 100 percent sure if the wires are still the same colours to match camera > cat5
I have cut off the POE connector off which has exposed some wires is there a diagram online that shows you how to wire these to CAT5/6 etc?
These images are from a video on youtube could anyone cofirm if these wires are correct or where the original diagrams are from thank you.
Yellow > Orange > Blue > Purple > Gray > Green > White > Brown
I have the same problem with my camera and have cut the cable and wired as you've mentioned, all working again now, big thank you!
Pin 1 Yellow
Pin 2 Orange
Pin 3 Blue
Pin 4 Purple
Pin 5 Gray
Pin 6 Green
Pin 7 White
Pin 8 Brown
Reactions: TonyR
Here is a lesson learned I wired up my Hikvision DS-2CD2386G2-ISU/SL camera around 3 years ago without using the waterproof connector supplied.
This is the reason it failed, no idea what's happened to the middle pins. The lesson here is always to use the waterproof connector supplied :)
