- Jun 7, 2016
- 378
- 154
DS-2CD2632F-IS V5.3.0 build 150513
illustrates typical video (note the timestamp)
having a lot of issues with this camera saving decent quality video on motion detection. Purchased camera to monitor licenses of vehicles travelling down road after a series of break-ins in the neighborhood (including my next-door neighbor).
Problem is the video is "jittery", almost as if the network connection is dropping in and out (it isn't -- I have other cameras on this same POE switch and they operate fine with no video distortion.) Symptom is the camera will "lose time"... e.g. it will simply jump over seconds at a time. In some cases, it will "miss" entire vehicles, or freeze the moment they come into range and the video will not 'pick up' again until they have driven past.
As a precaution I replaced the cat-6 line to the camera but it made no difference, so it appears to be a camera issue.
I am recording at 2048x1536, variable bitrate, highest quality, 15fps, which is typical of my other cameras (I have 13 other 2042's in turnouts and paddocks which record 2688x1520 variable highest 15fps without these symptoms -- this is the only 2632 I have -- but the 2042s probably aren't dealing with items moving as fast as vehicles, either.)
Any thoughts on how to correct? I've already dropped the frame rate down to 15 from 20, with no improvement. I would like to avoid losing picture quality since usually at 15fps I can only get 1 or 2 frames where the license plate is clearly visible.
Should I just swap to a different camera for this? I need a bullet camera with "zoom" feature since this camera is a bit off the road where it is set up.
