Hi everyone! I'm working on a Fisheye 6332FWD for a local school. I'm not sure if it is salvageable but I figured I'd try my luck on here before tossing it. I have searched and tried a ton of things I have found on this forum with no such luck. Here are the pertinent facts
-The camera does not show up in SADP.
-Camera will pull down certain firmwares (US) Namely anything from 5.09 series of updates (DOWNLOAD PORTAL)
-Camera will not reboot on its own after firmware update.
-I've opened the camera up and created a serial cable using very helpful posts from this forum
-Console shows the camera booting after upgrpade. It gets to "Load ramdisk" and will hang for around 20 minutes before proceeding. Here is the full boot sequence.
U-Boot 2.0.8-60298 (Dec 20 2013 - 16:00:12)
ARM Clock: 304MHz
DDR Clock: 528MHz
Cortex freq: 750MHz
Hit Ctrl+u to stop autoboot: 0
|BIND err|
Unknown command:null
nand booting ...
load kernel...
load ramdisk...
init started: BusyBox v1.19.3 (2014-09-11 13:45:58 CST)
starting pid 384, tty '': '/etc/init.d/rcS'
Starting udev: [ OK ]
starting pid 397, tty '': '/sbin/iptables -A INPUT -p tcp --dport 23 -j DROP'
starting pid 398, tty '': '/sbin/iptables -A INPUT -p tcp --dport 21 -j DROP'
starting pid 399, tty '': '/sbin/inetd -f -e /etc/inetd.conf'
starting pid 400, tty '': '-/bin/sh'
BusyBox v1.19.3 (2014-09-11 13:45:58 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
-Finally here is the kernel log from
# cat /proc/kmsg
<3>[ 916.601181] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 916.601193] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 916.601212] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 916.601225] Bad eraseblock 899 at 0x000007060000
<3>[ 917.601195] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 917.601207] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 917.601226] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 917.601239] Bad eraseblock 900 at 0x000007080000
<3>[ 918.601218] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 918.601231] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 918.601249] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 918.601263] Bad eraseblock 901 at 0x0000070a0000
<3>[ 919.601197] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 919.601209] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 919.601228] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 919.601241] Bad eraseblock 902 at 0x0000070c0000
<3>[ 920.601197] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 920.601209] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 920.601227] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 920.601241] Bad eraseblock 903 at 0x0000070e0000
<3>[ 921.601242] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 921.601255] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 921.601274] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 921.601289] Bad eraseblock 904 at 0x000007100000
<3>[ 922.601180] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 922.601192] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 922.601211] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 922.601225] Bad eraseblock 905 at 0x000007120000
<3>[ 923.601194] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 923.601206] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 923.601224] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 923.601238] Bad eraseblock 906 at 0x000007140000
<3>[ 924.601220] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 924.601233] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 924.601252] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 924.601266] Bad eraseblock 907 at 0x000007160000
<3>[ 925.601196] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 925.601209] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 925.601227] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 925.601241] Bad eraseblock 908 at 0x000007180000
<3>[ 926.601180] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 926.601191] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 926.601209] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 926.601224] Bad eraseblock 909 at 0x0000071a0000
<3>[ 927.601244] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 927.601257] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 927.601276] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 927.601290] Bad eraseblock 910 at 0x0000071c0000
<3>[ 928.601182] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 928.601194] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 928.601213] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 928.601226] Bad eraseblock 911 at 0x0000071e0000
<3>[ 929.601196] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 929.601208] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 929.601227] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 929.601240] Bad eraseblock 912 at 0x000007200000
<3>[ 930.601219] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 930.601231] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 930.601249] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 930.601263] Bad eraseblock 913 at 0x000007220000
<3>[ 931.601197] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 931.601209] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 931.601228] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 931.601242] Bad eraseblock 914 at 0x000007240000
<3>[ 932.601196] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 932.601209] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 932.601227] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 932.601241] Bad eraseblock 915 at 0x000007260000
<3>[ 933.601243] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 933.601256] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 933.601274] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 933.601287] Bad eraseblock 916 at 0x000007280000
<3>[ 934.601180] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 934.601192] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 934.601211] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 934.601224] Bad eraseblock 917 at 0x0000072a0000
<3>[ 935.601194] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 935.601207] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 935.601226] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 935.601240] Bad eraseblock 918 at 0x0000072c0000
<3>[ 936.601225] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 936.601238] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 936.601257] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 936.601270] Bad eraseblock 919 at 0x0000072e0000
<3>[ 937.601197] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 937.601209] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 937.601228] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 937.601242] Bad eraseblock 920 at 0x000007300000
<3>[ 938.601180] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 938.601191] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 938.601210] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 938.601223] Bad eraseblock 921 at 0x000007320000
<3>[ 939.601243] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 939.601256] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 939.601275] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 939.601288] Bad eraseblock 922 at 0x000007340000
<3>[ 940.601181] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 940.601194] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 940.601213] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 940.601226] Bad eraseblock 923 at 0x000007360000
<3>[ 941.601195] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 941.601207] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 941.601225] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 941.601239] Bad eraseblock 924 at 0x000007380000
<3>[ 942.601216] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 942.601228] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 942.601247] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 942.601261] Bad eraseblock 925 at 0x0000073a0000
<3>[ 943.601196] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 943.601209] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 943.601227] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 943.601241] Bad eraseblock 926 at 0x0000073c0000
<3>[ 944.601180] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 944.601193] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 944.601211] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 944.601224] Bad eraseblock 927 at 0x0000073e0000
<3>[ 945.601223] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 945.601236] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 945.601255] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 945.601268] Bad eraseblock 928 at 0x000007400000
<3>[ 946.601181] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 946.601193] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 946.601212] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 946.601225] Bad eraseblock 929 at 0x000007420000
<3>[ 947.601196] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 947.601208] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 947.601226] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 947.601240] Bad eraseblock 930 at 0x000007440000
<3>[ 948.601238] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 948.601250] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 948.601268] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 948.601283] Bad eraseblock 931 at 0x000007460000
<3>[ 949.601197] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 949.601210] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 949.601229] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 949.601243] Bad eraseblock 932 at 0x000007480000
<3>[ 950.601180] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 950.601192] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 950.601211] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 950.601224] Bad eraseblock 933 at 0x0000074a0000
<3>[ 951.601224] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 951.601236] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 951.601254] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 951.601268] Bad eraseblock 934 at 0x0000074c0000
<3>[ 952.601197] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 952.601210] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 952.601229] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 952.601242] Bad eraseblock 935 at 0x0000074e0000
<3>[ 953.601197] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 953.601209] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 953.601227] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 953.601241] Bad eraseblock 936 at 0x000007500000
<3>[ 954.601242] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 954.601253] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 954.601272] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 954.601286] Bad eraseblock 937 at 0x000007520000
<3>[ 955.601198] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 955.601211] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 955.601229] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 955.601243] Bad eraseblock 938 at 0x000007540000
<3>[ 956.601180] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 956.601192] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 956.601211] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 956.601224] Bad eraseblock 939 at 0x000007560000
<3>[ 957.601223] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 957.601236] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 957.601255] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 957.601269] Bad eraseblock 940 at 0x000007580000
<3>[ 958.601180] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 958.601192] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 958.601210] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 958.601224] Bad eraseblock 941 at 0x0000075a0000
<3>[ 959.601196] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 959.601208] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 959.601227] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 959.601241] Bad eraseblock 942 at 0x0000075c0000
<3>[ 960.601239] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 960.601251] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 960.601270] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 960.601283] Bad eraseblock 943 at 0x0000075e0000
<3>[ 961.601197] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 961.601209] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 961.601227] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 961.601241] Bad eraseblock 944 at 0x000007600000
<3>[ 962.601180] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 962.601192] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 962.601210] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 962.601224] Bad eraseblock 945 at 0x000007620000
<3>[ 963.601229] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 963.601241] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 963.601259] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 963.601273] Bad eraseblock 946 at 0x000007640000
<3>[ 964.601182] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 964.601195] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 964.601214] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 964.601228] Bad eraseblock 947 at 0x000007660000
<3>[ 965.601196] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 965.601209] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 965.601228] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 965.601241] Bad eraseblock 948 at 0x000007680000
<3>[ 966.601239] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 966.601252] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 966.601270] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 966.601284] Bad eraseblock 949 at 0x0000076a0000
<3>[ 967.601196] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 967.601209] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 967.601228] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 967.601242] Bad eraseblock 950 at 0x0000076c0000
<3>[ 968.601197] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 968.601209] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 968.601228] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 968.601242] Bad eraseblock 951 at 0x0000076e0000
<3>[ 969.601223] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 969.601236] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 969.601255] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 969.601268] Bad eraseblock 952 at 0x000007700000
<3>[ 970.601180] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 970.601192] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 970.601211] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 970.601225] Bad eraseblock 953 at 0x000007720000
<3>[ 971.601195] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 971.601207] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 971.601226] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 971.601239] Bad eraseblock 954 at 0x000007740000
<3>[ 972.601239] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 972.601252] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 972.601270] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 972.601284] Bad eraseblock 955 at 0x000007760000
<3>[ 973.601197] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 973.601209] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 973.601228] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 973.601242] Bad eraseblock 956 at 0x000007780000
<3>[ 974.601180] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 974.601192] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 974.601211] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 974.601225] Bad eraseblock 957 at 0x0000077a0000
<3>[ 975.601224] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 975.601237] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 975.601255] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 975.601269] Bad eraseblock 958 at 0x0000077c0000
<3>[ 976.601181] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 976.601193] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 976.601211] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 976.601224] Bad eraseblock 959 at 0x0000077e0000
<3>[ 977.601195] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 977.601207] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 977.601225] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 977.601239] Bad eraseblock 960 at 0x000007800000
<3>[ 978.601239] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 978.601252] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 978.601271] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 978.601285] Bad eraseblock 961 at 0x000007820000
<3>[ 979.601196] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 979.601208] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 979.601227] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 979.601241] Bad eraseblock 962 at 0x000007840000
<3>[ 980.601180] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 980.601192] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 980.601211] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 980.601224] Bad eraseblock 963 at 0x000007860000
<3>[ 981.601224] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 981.601236] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 981.601255] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 981.601269] Bad eraseblock 964 at 0x000007880000
<3>[ 982.601180] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 982.601193] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 982.601212] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 982.601226] Bad eraseblock 965 at 0x0000078a0000
<3>[ 983.601195] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 983.601207] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 983.601225] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 983.601238] Bad eraseblock 966 at 0x0000078c0000
<3>[ 984.601249] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 984.601261] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 984.601280] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 984.601293] Bad eraseblock 967 at 0x0000078e0000
<3>[ 985.601197] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 985.601210] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 985.601229] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 985.601242] Bad eraseblock 968 at 0x000007900000
<3>[ 986.601180] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 986.601192] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 986.601210] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 986.601224] Bad eraseblock 969 at 0x000007920000
<3>[ 987.601222] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 987.601235] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 987.601253] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 987.601267] Bad eraseblock 970 at 0x000007940000
<3>[ 988.601181] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 988.601193] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 988.601212] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 988.601226] Bad eraseblock 971 at 0x000007960000
<3>[ 989.601196] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 989.601208] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 989.601227] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 989.601242] Bad eraseblock 972 at 0x000007980000
<3>[ 990.601239] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 990.601251] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 990.601270] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 990.601284] Bad eraseblock 973 at 0x0000079a0000
<3>[ 991.601198] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 991.601210] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 991.601229] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 991.601243] Bad eraseblock 974 at 0x0000079c0000
<3>[ 992.601180] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 992.601191] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 992.601209] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 992.601223] Bad eraseblock 975 at 0x0000079e0000
<3>[ 993.601224] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 993.601237] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 993.601255] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 993.601269] Bad eraseblock 976 at 0x000007a00000
<3>[ 994.601197] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 994.601209] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 994.601228] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 994.601241] Bad eraseblock 977 at 0x000007a20000
<3>[ 995.601195] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 995.601207] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 995.601226] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 995.601239] Bad eraseblock 978 at 0x000007a40000
<3>[ 996.601239] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 996.601252] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 996.601270] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 996.601284] Bad eraseblock 979 at 0x000007a60000
<3>[ 997.601197] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 997.601209] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 997.601228] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 997.601241] Bad eraseblock 980 at 0x000007a80000
<3>[ 998.601181] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 998.601193] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 998.601212] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 998.601225] Bad eraseblock 981 at 0x000007aa0000
<3>[ 999.601223] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 999.601235] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 999.601254] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 999.601268] Bad eraseblock 982 at 0x000007ac0000
<3>[ 1000.601198] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1000.601211] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1000.601230] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1000.601244] Bad eraseblock 983 at 0x000007ae0000
<3>[ 1001.601195] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1001.601208] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1001.601226] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1001.601240] Bad eraseblock 984 at 0x000007b00000
<3>[ 1002.601239] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1002.601252] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1002.601271] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1002.601285] Bad eraseblock 985 at 0x000007b20000
<3>[ 1003.601198] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1003.601210] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1003.601229] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1003.601243] Bad eraseblock 986 at 0x000007b40000
<3>[ 1004.601179] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1004.601191] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1004.601210] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1004.601223] Bad eraseblock 987 at 0x000007b60000
<3>[ 1005.601220] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1005.601233] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1005.601252] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1005.601266] Bad eraseblock 988 at 0x000007b80000
<3>[ 1006.601180] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1006.601193] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1006.601211] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1006.601225] Bad eraseblock 989 at 0x000007ba0000
<3>[ 1007.601195] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1007.601207] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1007.601225] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1007.601239] Bad eraseblock 990 at 0x000007bc0000
<3>[ 1008.601239] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1008.601251] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1008.601270] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1008.601284] Bad eraseblock 991 at 0x000007be0000
<3>[ 1009.601197] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1009.601210] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1009.601228] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1009.601242] Bad eraseblock 992 at 0x000007c00000
<3>[ 1010.601180] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1010.601192] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1010.601210] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1010.601224] Bad eraseblock 993 at 0x000007c20000
<3>[ 1011.601223] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1011.601235] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1011.601254] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1011.601267] Bad eraseblock 994 at 0x000007c40000
<3>[ 1012.601180] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1012.601192] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1012.601211] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1012.601224] Bad eraseblock 995 at 0x000007c60000
<3>[ 1013.601195] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1013.601208] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1013.601226] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1013.601239] Bad eraseblock 996 at 0x000007c80000
<3>[ 1014.601241] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1014.601253] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1014.601272] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1014.601286] Bad eraseblock 997 at 0x000007ca0000
<3>[ 1015.601199] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1015.601211] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1015.601229] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1015.601243] Bad eraseblock 998 at 0x000007cc0000
<3>[ 1016.601197] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1016.601209] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1016.601228] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1016.601241] Bad eraseblock 999 at 0x000007ce0000
<3>[ 1017.601222] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1017.601234] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1017.601254] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1017.601269] Bad eraseblock 1000 at 0x000007d00000
<3>[ 1018.601181] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1018.601193] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1018.601212] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1018.601226] Bad eraseblock 1001 at 0x000007d20000
<3>[ 1019.601196] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1019.601208] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1019.601227] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1019.601241] Bad eraseblock 1002 at 0x000007d40000
<3>[ 1020.601239] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1020.601251] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1020.601270] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1020.601284] Bad eraseblock 1003 at 0x000007d60000
<3>[ 1021.601197] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1021.601210] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1021.601229] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1021.601243] Bad eraseblock 1004 at 0x000007d80000
<3>[ 1022.601180] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1022.601193] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1022.601212] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1022.601226] Bad eraseblock 1005 at 0x000007da0000
<3>[ 1023.601222] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1023.601234] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1023.601252] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1023.601266] Bad eraseblock 1006 at 0x000007dc0000
<3>[ 1024.601182] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1024.601194] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1024.601213] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1024.601227] Bad eraseblock 1007 at 0x000007de0000
<3>[ 1025.601200] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1025.601212] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1025.601231] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1025.601244] Bad eraseblock 1008 at 0x000007e00000
<3>[ 1026.601241] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1026.601254] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1026.601273] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1026.601288] Bad eraseblock 1009 at 0x000007e20000
<3>[ 1027.601196] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1027.601209] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1027.601227] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1027.601241] Bad eraseblock 1010 at 0x000007e40000
<3>[ 1028.601179] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1028.601191] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1028.601209] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1028.601224] Bad eraseblock 1011 at 0x000007e60000
<3>[ 1029.601223] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1029.601235] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1029.601254] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1029.601268] Bad eraseblock 1012 at 0x000007e80000
<3>[ 1030.601180] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1030.601192] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1030.601211] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1030.601224] Bad eraseblock 1013 at 0x000007ea0000
<3>[ 1031.601195] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1031.601207] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1031.601225] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1031.601239] Bad eraseblock 1014 at 0x000007ec0000
<3>[ 1032.601249] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1032.601262] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1032.601280] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1032.601295] Bad eraseblock 1015 at 0x000007ee0000
<3>[ 1033.601197] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1033.601209] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1033.601228] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1033.601242] Bad eraseblock 1016 at 0x000007f00000
<3>[ 1034.601180] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1034.601192] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1034.601211] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1034.601225] Bad eraseblock 1017 at 0x000007f20000
<3>[ 1035.601222] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1035.601235] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1035.601253] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1035.601268] Bad eraseblock 1018 at 0x000007f40000
<3>[ 1036.601181] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1036.601193] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1036.601212] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1036.601226] Bad eraseblock 1019 at 0x000007f60000
<3>[ 1037.601195] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1037.601207] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1037.601226] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1037.601240] Bad eraseblock 1020 at 0x000007f80000
<3>[ 1038.601240] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1038.601253] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1038.601271] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1038.601286] Bad eraseblock 1021 at 0x000007fa0000
<3>[ 1039.601195] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1039.601208] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1039.601227] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1039.601241] Bad eraseblock 1022 at 0x000007fc0000
<3>[ 1040.601179] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe timeo
<3>[ 1040.601192] fio_dma_parse_error: fio dma read error 0x5000800.
<3>[ 1040.601210] ambarella-nand ambarella-nand: nand_amb_request: cmd=0xe, addr
<4>[ 1040.601224] Bad eraseblock 1023 at 0x000007fe0000
<3>[ 1040.601232] No space left to write bad block table
<4>[ 1040.601311] ambarella-nand: probe of ambarella-nand failed with error -28
<6>[ 1041.005412] libphy: Ambarella MII Bus: probed
<5>[ 1041.206656] ambarella-eth ambarella-eth.0: MAC Address[44:19:b7:2f:bb:0b].
<6>[ 1041.206845] PPP generic driver version 2.4.2
<6>[ 1041.207255] PPP BSD Compression module registered
<6>[ 1041.207269] PPP Deflate Compression module registered
<6>[ 1041.207697] mousedev: PS/2 mouse device common for all mice
<6>[ 1041.208042] ambarella-rtc ambarella-rtc: rtc core: registered ambarella-rt
<5>[ 1041.208560] ambarella-wdt ambarella-wdt: Ambarella Media Processor Watch D
<6>[ 1041.209542] Netfilter messages via NETLINK v0.30.
<6>[ 1041.209617] nf_conntrack version 0.5.0 (9953 buckets, 39812 max)
<6>[ 1041.210101] ip_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 1041.210211] TCP: cubic registered
<6>[ 1041.210292] NET: Registered protocol family 10
<6>[ 1041.211299] ip6_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 1041.211365] sit: IPv6 over IPv4 tunneling driver
<6>[ 1041.213481] ip6_gre: GRE over IPv6 tunneling driver
<6>[ 1041.214535] NET: Registered protocol family 17
<6>[ 1041.216845] sctp: Hash tables configured (established 65536 bind 65536)
<7>[ 1041.217077] sctp: sctp_init_sock(sk: a7448c00)
<6>[ 1041.217256] VFP support v0.3: implementor 41 architecture 3 part 30 varian
<6>[ 1041.217281] ThumbEE CPU extension supported.
<6>[ 1041.217323] ambarella_gpio_irq_set_wake: irq[305] = girq[49] = 1
<3>[ 1041.217336] ambarella_init_uport_switcher: request uport_switcher gpio fai
<6>[ 1041.219369] console [netcon0] enabled
<6>[ 1041.219382] netconsole: network logging started
<6>[ 1041.219435] ambarella-rtc ambarella-rtc: setting system clock to 1970-01-1
<5>[ 1041.219916] RAMDISK: gzip image found at block 0
<6>[ 1041.548629] VFS: Mounted root (ext2 filesystem) on device 1:0.
<6>[ 1041.548921] Freeing init memory: 196K
Looks like a ton of memory errors. Am I looking at a hardware failure? Any help would be greatly appreciated, thanks everyone.
ARM Clock: 304MHz
DDR Clock: 528MHz
Cortex freq: 750MHz
|BIND err|
nand booting ...
load kernel...
load ramdisk...
# cat /proc/kmsg
