I think it's no promblem, to change you secured password and set not securen(123456) and make debug again
At your DS-7616NI-I2/16P that the Custom RTSP string you use to connect this Wize CAM for 1st & 2nd stream?
You can use ffmpeg to get stream from your Wise CAM & save data to file & log to log file to analise it.
If you use VLC, so make screanshot from live stream pressind Ctrl-I from codec tab
Thanks for the tip, I have pasted a debug of the VLC stream. It plays fine from VLC. Maybe the issue is the audio stream on Hikvision NVRs? Do you see anything unusual in the stream? I have also attached the codec log from VLC.
main debug: processing request item: rtsp:/192.168.1.93/live, node: Playlist, skip: 0
main debug: resyncing on rtsp:/192.168.1.93/live
main debug: rtsp:/192.168.1.93/live is at 0
main debug: starting playback of new item
main debug: creating new input thread
main debug: Creating an input for 'rtsp:/192.168.1.93/live'
main debug: requesting art for new input thread
main debug: using timeshift granularity of 50 MiB
main debug: using timeshift path: C:\Users\!\AppData\Local\Temp
main debug: `rtsp:/!@192.168.1.93:/live' gives access `rtsp' demux
any' path !@192.168.1.93:/live'
main debug: creating demux: access='rtsp' demux='any' location='!@192.168.1.93:/live' file='\\!:!@192.168.1.93:\live'
main debug: looking for access_demux module matching "rtsp": 15 candidates
live555 debug: version 2016.11.28
main debug: looking for meta fetcher module matching "any": 1 candidates
main warning: Password in a URI is DEPRECATED
lua debug: Trying Lua scripts in C:\Users\!\AppData\Roaming\vlc\lua\meta\fetcher
lua debug: Trying Lua scripts in C:\Program Files\VideoLAN\VLC\lua\meta\fetcher
main debug: no meta fetcher modules matched
main debug: looking for art finder module matching "any": 2 candidates
lua debug: Trying Lua scripts in C:\Users\!\AppData\Roaming\vlc\lua\meta\art
lua debug: Trying Lua scripts in C:\Program Files\VideoLAN\VLC\lua\meta\art
lua debug: Trying Lua playlist script C:\Program Files\VideoLAN\VLC\lua\meta\art\00_musicbrainz.luac
lua debug: skipping script (unmatched scope) C:\Program Files\VideoLAN\VLC\lua\meta\art\00_musicbrainz.luac
lua debug: Trying Lua playlist script C:\Program Files\VideoLAN\VLC\lua\meta\art\01_googleimage.luac
lua debug: skipping script (unmatched scope) C:\Program Files\VideoLAN\VLC\lua\meta\art\01_googleimage.luac
lua debug: Trying Lua playlist script C:\Program Files\VideoLAN\VLC\lua\meta\art\02_frenchtv.luac
lua debug: skipping script (unmatched scope) C:\Program Files\VideoLAN\VLC\lua\meta\art\02_frenchtv.luac
lua debug: Trying Lua playlist script C:\Program Files\VideoLAN\VLC\lua\meta\art\03_lastfm.luac
lua debug: skipping script (unmatched scope) C:\Program Files\VideoLAN\VLC\lua\meta\art\03_lastfm.luac
main debug: no art finder modules matched
qt debug: IM: Setting an input
live555 debug: RTP subsession 'video/H264'
main debug: selecting program id=0
live555 debug: RTP subsession 'audio/PCMA'
live555 debug: setup start: 0.000000 stop:0.000000
live555 debug: We have a timeout of 10 seconds
live555 debug: play start: 0.000000 stop:0.000000
main debug: using access_demux module "live555"
main debug: looking for packetizer module matching "any": 25 candidates
h264 debug: found NAL_SPS (sps_id=0)
h264 debug: found NAL_PPS (pps_id=0 sps_id=0)
main debug: using packetizer module "h264"
main debug: looking for video decoder module matching "any": 19 candidates
avcodec debug: using ffmpeg Lavc58.6.103
avcodec debug: CPU flags: 0x000fd3db
avcodec debug: allowing 6 thread(s) for decoding
avcodec debug: codec (h264) started
avcodec debug: using frame thread mode with 6 threads
main debug: using video decoder module "avcodec"
main debug: looking for audio decoder module matching "any": 23 candidates
g711 debug: samplerate:16000Hz channels:1
main debug: using audio decoder module "g711"
main debug: looking for meta reader module matching "any": 2 candidates
lua debug: Trying Lua scripts in C:\Users\!\AppData\Roaming\vlc\lua\meta\reader
lua debug: Trying Lua scripts in C:\Program Files\VideoLAN\VLC\lua\meta\reader
lua debug: Trying Lua playlist script C:\Program Files\VideoLAN\VLC\lua\meta\reader\filename.luac
main debug: no meta reader modules matched
main debug: `rtsp:/!:!@192.168.1.93:/live' successfully opened
live555 warning: no data received in 10s. Switching to TCP
main debug: killing decoder fourcc `h264'
main debug: removing module "avcodec"
main debug: removing module "h264"
main debug: killing decoder fourcc `alaw'
main debug: removing module "g711"
main debug: Program doesn't contain anymore ES
live555 debug: tk->rtpSource->hasBeenSynchronizedUsingRTCP()
main debug: Buffering 0%
main debug: Buffering 1%
main debug: reusing audio output
main debug: looking for aout stream module matching "any": 2 candidates
main debug: Buffering 3%
wasapi debug: modified format
wasapi debug: buffer size : 96000 frames
wasapi debug: maximum latency: 000 ns
wasapi debug: default period : 10000000 ns
wasapi debug: minimum period : 3000000 ns
main debug: using aout stream module "wasapi"
main debug: output 'f32l' 48000 Hz Stereo frame=1 samples/8 bytes
main debug: looking for audio volume module matching "any": 2 candidates
main debug: using audio volume module "float_mixer"
main debug: input 's16l' 16000 Hz Mono frame=1 samples/2 bytes
main debug: looking for audio filter module matching "scaletempo": 16 candidates
scaletempo debug: format: 16000 rate, 1 nch, 4 bps, fl32
scaletempo debug: params: 30 stride, 0.200 overlap, 14 search
scaletempo debug: 1.000 scale, 480.000 stride_in, 480 stride_out, 384 standing, 96 overlap, 224 search, 800 queue, fl32 mode
main debug: using audio filter module "scaletempo"
main debug: conversion: 's16l'->'f32l' 16000 Hz->16000 Hz Mono->Mono
main debug: looking for audio converter module matching "any": 8 candidates
audio_format debug: s16l->f32l, bits per sample: 16->32
main debug: using audio converter module "audio_format"
main debug: conversion pipeline complete
main debug: conversion: 'f32l'->'f32l' 16000 Hz->16000 Hz Mono->Stereo
main debug: using audio converter module "trivial"
main debug: looking for audio resampler module matching "any": 3 candidates
main debug: using audio resampler module "samplerate"
main debug: Buffering 7%
main debug: Buffering 30%
main debug: Buffering 34%
main debug: Buffering 38%
main debug: Buffering 40%
main debug: Buffering 45%
main debug: Buffering 46%
main debug: Buffering 50%
main debug: Buffering 55%
main debug: Buffering 60%
main debug: Buffering 62%
main debug: Buffering 65%
main debug: Buffering 70%
main debug: Buffering 75%
main debug: Buffering 78%
main debug: Buffering 80%
main debug: Buffering 85%
main debug: Buffering 86%
main debug: Buffering 90%
main debug: Buffering 95%
main debug: Buffering 100%
main debug: Stream buffering done (1025 ms in 900 ms)
main error: buffer deadlock prevented
main debug: Decoder wait done in 0 ms
main debug: inserting 23290 zeroes
mmdevice debug: state changed: 1
main warning: playback too early (-80858): down-sampling
main debug: restarting module due to input format change
avcodec debug: available hardware decoder output format 119 (cuda)
avcodec debug: available hardware decoder output format 53 (dxva2_vld)
avcodec debug: available hardware decoder output format 118 (d3d11va_vld)
avcodec debug: available hardware decoder output format 174 (d3d11)
avcodec debug: available software decoder output format 0 (yuv420p)
avcodec debug: trying format d3d11va_vld
main debug: looking for text renderer module matching "any": 3 candidates
freetype debug: Using DWrite backend
freetype debug: DWrite_GetFamily(): family name: Arial
freetype debug: DWrite_ParseFamily(): using font at index 0 with weight 400 for bold: 0, italic: 0
freetype debug: DWrite_ParseFamily(): using font at index 1 with weight 700 for bold: 1, italic: 0
freetype debug: DWrite_ParseFamily(): using font at index 2 with weight 400 for bold: 0, italic: 1
freetype debug: DWrite_ParseFamily(): using font at index 3 with weight 700 for bold: 1, italic: 1
main debug: using text renderer module "freetype"
main debug: looking for video converter module matching "any": 24 candidates
swscale debug: 32x32 (32x32) chroma: YUVA -> 16x16 (16x16) chroma: RGBA with scaling using Bicubic (good quality)
main debug: using video converter module "swscale"
yuvp debug: YUVP to YUVA converter
main debug: using video converter module "yuvp"
main debug: Deinterlacing available
main debug: deinterlace -1, mode auto, is_needed 0
main debug: looking for vout window module matching "qt,any": 3 candidates
qt debug: requesting video window...
main debug: resized to 600x277
main debug: resized to 1920x1080
main debug: using vout window module "qt"
main debug: looking for inhibit module matching "any": 1 candidates
main debug: using inhibit module "inhibit"
main debug: Opening vout display wrapper
main debug: looking for vout display module matching "any": 12 candidates
direct3d11 debug: creating Vout EventThread
direct3d11 debug: Win32VoutCreateWindow
main debug: VoutDisplayEvent 'resize' 1920x1080
direct3d11 debug: inclinometer not found. (hr=0x80070490)
direct3d11 debug: created video sub-window
direct3d11 debug: Vout EventThread running
qt debug: Logical video size: 1920x1080
direct3d11 debug: Created the D3D11 device type 1 level b100.
direct3d11 debug: NVIDIA WDDM driver 30.0.14.9729
direct3d11 debug: supports colorspace RGB Rec.709 gamma:22 range:FULL
direct3d11 debug: supports colorspace RGB Rec.709 gamma:22 range:STUDIO
direct3d11 debug: supports colorspace RGB Rec.2020 gamma:22 range:STUDIO
direct3d11 debug: supports colorspace RGB Rec.2020 gamma:22 range:FULL
direct3d11 debug: supports colorspace RGB Rec.2020 gamma:2084 range:FULL
direct3d11 debug: supports colorspace RGB Rec.2020 gamma:2084 range:STUDIO
direct3d11 debug: Output max luminance: 343.7, colorspace RGB Rec.709 gamma:22 range:FULL, bits per pixel 8
direct3d11 debug: using colorspace RGB Rec.709 gamma:22 range:FULL
direct3d11 debug: Using pixel format VA_NV12 for chroma DX11
main debug: VoutDisplayEvent 'resize' 1942x1136
direct3d11 debug: using GPU render fence
direct3d11 debug: Direct3D11 resources created
direct3d11 debug: Direct3D11 device adapter successfully initialized
direct3d11 debug: Direct3D11 Open Succeeded
main debug: using vout display module "direct3d11"
direct3d11 debug: D3D11 pool succeed with 40 surfaces (1920x1152) context 0x0000021786151d60
main debug: original format sz 1920x1088, of (0,0), vsz 1920x1080, 4cc DX11, sar 1:1, msk r0x0 g0x0 b0x0
main debug: removing module "freetype"
direct3d11 debug: Detected size change 1920x1080
main debug: looking for hw decoder module matching "d3d11va": 2 candidates
d3d11va debug: NVIDIA WDDM driver 30.0.14.9729
d3d11va debug: Reusing Direct3D11 device
d3d11va debug: CreateDevice succeed
d3d11va debug: - 'MPEG-2 & MPEG-1 variable-length decoder' is supported
d3d11va debug: - 'MPEG-2 variable-length decoder' is supported
d3d11va debug: - 'MPEG-1 variable-length decoder, no D pictures' is supported
d3d11va debug: - 'VC-1 variable-length decoder' is supported
d3d11va debug: - 'Unknown decoder 0x32fcfe3f-0xde46-0x4a49-0x861bac71110649d5' is supported
d3d11va debug: - 'H.264 stereo high profile, mbs flag set' is supported
d3d11va debug: - 'H.264 stereo high profile' is supported
d3d11va debug: - 'H.264 variable-length decoder, no film grain technology' is supported
d3d11va debug: - 'HEVC Main profile' is supported
d3d11va debug: - 'HEVC Main 10 profile' is supported
d3d11va debug: - 'Unknown decoder 0x20bb8b0a-0x97aa-0x4571-0x8e9964e60606c1a6' is supported
d3d11va debug: - 'Unknown decoder 0x15df9b21-0x06c4-0x47f1-0x841ea67c97d7f312' is supported
d3d11va debug: - 'MPEG-4 Part 2 variable-length decoder, Simple Profile' is supported
d3d11va debug: - 'MPEG-4 Part 2 variable-length decoder, Simple&Advanced Profile, no GMC' is supported
d3d11va debug: - 'MPEG-4 Part 2 nVidia bitstream decoder' is supported
d3d11va debug: - 'Unknown decoder 0x33fcfe41-0xde46-0x4a49-0x861bac71110649d5' is supported
d3d11va debug: - 'VP9 profile 0' is supported
d3d11va debug: - 'VP9 profile 2' is supported
d3d11va debug: - 'Unknown decoder 0xdda19dc7-0x93b5-0x49f5-0xa9b32bda28a2ce6e' is supported
d3d11va debug: - 'Unknown decoder 0x6affd11e-0x1d96-0x42b1-0xa21593a31f09a53d' is supported
d3d11va debug: - 'Unknown decoder 0x914c84a3-0x4078-0x4fa9-0x984ce2f262cb5c9c' is supported
d3d11va debug: - 'Unknown decoder 0x8a1a1031-0x29bc-0x46d0-0xa007e9b092ca6767' is supported
d3d11va debug: Trying to use 'H.264 variable-length decoder, no film grain technology' as input
d3d11va debug: NV12 output is supported for decoder H.264 variable-length decoder, no film grain technology.
d3d11va debug: Using output format NV12 for decoder H.264 variable-length decoder, no film grain technology
d3d11va debug: va_pool_SetupDecoder id 27 1920x1088 count: 24
d3d11va warning: not enough decoding slices in the texture (6/24)
d3d11va debug: ID3D11VideoDecoderOutputView succeed with 24 surfaces (1920x1088)
d3d11va debug: we got 3 decoder configurations
d3d11va debug: configuration[0] ConfigBitstreamRaw 1
d3d11va debug: configuration[1] ConfigBitstreamRaw 2
d3d11va debug: configuration[2] ConfigBitstreamRaw 2
d3d11va debug: DxCreateDecoderSurfaces succeed
main debug: using hw decoder module "d3d11va"
avcodec info: Using D3D11VA (NVIDIA GeForce GTX 1660 SUPER, vendor 10de(NVIDIA), device 21c4, revision a1) for hardware decoding
main warning: playback too late (81815): up-sampling
main debug: resampling stopped (drift: 70881 us)
main warning: playback too late (76381): up-sampling
main debug: auto hiding mouse cursor
main warning: playback way too early (-277542): playing silence
main debug: inserting 13322 zeroes
main warning: playback way too early (-162955): playing silence
main debug: inserting 7821 zeroes
main warning: playback too early (-78136): down-sampling
main warning: playback way too late (231381): flushing buffers
mmdevice debug: state changed: 0
wasapi debug: reset
main debug: inserting 68443 zeroes
main warning: playback way too late (181545): flushing buffers
wasapi debug: reset
main debug: inserting 64767 zeroes
main warning: playback too late (61676): up-sampling
main warning: picture is too late to be displayed (missing 260 ms)
main warning: picture is too late to be displayed (missing 210 ms)
main warning: picture is too late to be displayed (missing 331 ms)
main warning: picture is too late to be displayed (missing 281 ms)
main warning: picture is too late to be displayed (missing 275 ms)
main warning: picture is too late to be displayed (missing 225 ms)
main warning: picture is too late to be displayed (missing 175 ms)
main warning: picture is too late to be displayed (missing 124 ms)
main warning: picture is too late to be displayed (missing 75 ms)
main warning: picture is too late to be displayed (missing 25 ms)
main warning: playback way too early (-487145): playing silence
main debug: inserting 23382 zeroes
main warning: playback way too late (285937): flushing buffers
wasapi debug: reset
main debug: inserting 67795 zeroes
main warning: playback way too late (217960): flushing buffers
wasapi debug: reset
main debug: inserting 64249 zeroes
main warning: playback too late (70244): up-sampling
main warning: picture is too late to be displayed (missing 224 ms)
main warning: picture is too late to be displayed (missing 173 ms)
main warning: picture is too late to be displayed (missing 336 ms)
main warning: picture is too late to be displayed (missing 286 ms)
main warning: picture is too late to be displayed (missing 235 ms)
main warning: picture is too late to be displayed (missing 223 ms)
main warning: picture is too late to be displayed (missing 174 ms)
main warning: picture is too late to be displayed (missing 73 ms)
main debug: picture might be displayed late (missing 24 ms)
main warning: playback way too early (-453320): playing silence
main debug: inserting 21759 zeroes
main warning: playback way too late (376055): flushing buffers
wasapi debug: reset
main debug: inserting 68855 zeroes
main warning: playback too late (153062): up-sampling
main warning: playback way too late (180461): flushing buffers
wasapi debug: reset
main debug: inserting 60927 zeroes
main warning: picture is too late to be displayed (missing 488 ms)
main warning: picture is too late to be displayed (missing 438 ms)
main warning: picture is too late to be displayed (missing 388 ms)
main warning: picture is too late to be displayed (missing 338 ms)
main warning: picture is too late to be displayed (missing 288 ms)
main warning: picture is too late to be displayed (missing 246 ms)
main warning: picture is too late to be displayed (missing 196 ms)
main warning: picture is too late to be displayed (missing 145 ms)
main warning: picture is too late to be displayed (missing 95 ms)
main warning: picture is too late to be displayed (missing 46 ms)
main warning: playback way too early (-524340): playing silence
main debug: inserting 25168 zeroes
main warning: playback way too late (231115): flushing buffers
wasapi debug: reset
main debug: inserting 68254 zeroes
main warning: playback way too late (222374): flushing buffers
wasapi debug: reset
main debug: inserting 67147 zeroes
main warning: playback too late (91517): up-sampling
main warning: picture is too late to be displayed (missing 183 ms)
main warning: picture is too late to be displayed (missing 335 ms)
main warning: picture is too late to be displayed (missing 285 ms)
main warning: picture is too late to be displayed (missing 309 ms)
main warning: picture is too late to be displayed (missing 258 ms)
main warning: picture is too late to be displayed (missing 159 ms)
main warning: picture is too late to be displayed (missing 157 ms)
main warning: picture is too late to be displayed (missing 107 ms)
main warning: picture is too late to be displayed (missing 57 ms)
main debug: picture might be displayed late (missing 8 ms)
main warning: playback way too early (-565157): playing silence
main debug: inserting 27127 zeroes
main warning: playback way too early (-154027): playing silence
main debug: inserting 7393 zeroes
main warning: playback way too late (312785): flushing buffers
wasapi debug: reset
main debug: inserting 74305 zeroes
main warning: playback way too late (303043): flushing buffers
wasapi debug: reset
main debug: inserting 72993 zeroes
main warning: playback too late (61455): up-sampling
main warning: timing screwed (drift: 149066 us): stopping resampling
main warning: playback too late (149900): up-sampling
main warning: playback way too late (198395): flushing buffers
wasapi debug: reset
main debug: inserting 63336 zeroes
main warning: picture is too late to be displayed (missing 267 ms)
main warning: picture is too late to be displayed (missing 217 ms)
main warning: picture is too late to be displayed (missing 167 ms)
main warning: picture is too late to be displayed (missing 117 ms)
main warning: picture is too late to be displayed (missing 67 ms)
main warning: picture is too late to be displayed (missing 259 ms)
main warning: picture is too late to be displayed (missing 209 ms)
main warning: picture is too late to be displayed (missing 154 ms)
main warning: picture is too late to be displayed (missing 104 ms)
main warning: picture is too late to be displayed (missing 54 ms)
main debug: picture might be displayed late (missing 4 ms)
main warning: picture is too late to be displayed (missing 44 ms)
main warning: playback too late (67999): up-sampling
main debug: incoming request - stopping current input
main debug: saving a free vout
main debug: reusing provided vout
wasapi debug: reset
main debug: removing module "samplerate"
main debug: removing module "audio_format"
main debug: removing module "scaletempo"
main debug: removing module "trivial"
main debug: removing module "float_mixer"
main debug: keeping audio output
main debug: removing module "live555"
main debug: dead input
main debug: nothing to play
main debug: destroying useless vout
main debug: removing module "direct3d11"
direct3d11 debug: Direct3D11 resources destroyed
qt debug: IM: Deleting the input
direct3d11 debug: Direct3D11 device adapter closed
direct3d11 error: SetThumbNailClip failed: 0x800706f4
direct3d11 debug: Win32 Vout EventThread terminating
direct3d11 debug: Win32VoutCloseWindow
direct3d11 debug: WinProc WM_DESTROY
main debug: removing module "inhibit"
qt debug: releasing video...
