EmpireTech aka Dahua LPR Settings
Oh yeah missed the fog - I thought it was IR bounce, well it is off the fog LOL
  • Haha
Click on the Purple and drag your mouse across the day to define Night and do same with the Orange to define day.
Make sure they match perfect and no spaces between the purple and orange.
I think when you do that it will automatically go to Customized Scene at top? Cant recall
Lower gain to 45
Do you have AI SSA on or off? It should be off.
Now as others have posted, focus is an issue as the camera cannot see anything at this darkness.
You need to either have someone stop in the middle of the field of view so you can get a focus or temporarily make the shutter like 1/12 or something slow so you can see and manually set the focus based on what you see in the field of view, but the plate is the best option.
I’ll have to go park the car out there when it’s better weather tomorrow with no fog
I’ll click customize scene. I haven’t seen that screen you posted im the screenshot
The Time Plan settings? Its collapsed until you click on it, it hides. Easy to miss
Much better! Congrats
Now you could play with various parameters to dial it in.
I ended up buying a second camera to face the other direction. What do you think of the placement?
With it zoomed in
LPR is addictive...well cameras in general LOL
Angle might be a little tight, but if you can read them!
I would also consider to the other side of the darker utility pole for a better angle if the distance isn't too great.
This always as a rule of thumb, reduce the angle
Reactions: Parley
I assume you are using your other LPR settings as a starting point?
And if so, that shows how different each field of view is and each camera.
I would start with lowering NR and next would be increase shutter.
Yes same baseline from the other camera. This is the current settings.
