CCTVCam
- Sep 25, 2017
- 3,167
- 4,099
I switched to Brave. I learned from another poster that you just have to close the plugin message even though it's installed. Still not perfect because certain functions don't work 100%
In case anyone cares, Firefox works perfectly. So, I've switched to that.
Are you absolutely sure and how long have you tested them for? What tends to happen with browsers other than IE, is they all "work". It's just after you save changes and come back a couple of weeks later, you can find the changes haven't been implemented / reverted despite a confirmation on exit saying they have. Particularly affected seem to be changes to compression ie Bit rates, Codecs and Streams. I forget the number of times I've set 15,000K as the bit rate on the main stream, 2nd stream as the chosen stream on the sub stream, resolution of 1080p on the sub and a bit rate of 8000k on the sub only to find that any one of those paramsters has changed - frequently on the sub it changes to low resolution or stream source entirely to sub stream 1 from 2, in non IE browsers. All changes look fine when you exit. It's only some time after you tend to discover they have changed. I love Firefox and use Brave to browse news sites to stop pop ups. However, I've yet to see anyone recommend anything other than Pale Moon or IE as a good means of saving changes in Dahua cameras. Even then for me, I reverted to IE as it was the only consistent browser in my experience.
