EmpireTech NVR8CH-8P-2AI - Setup Questions
kd4e
Jun 11, 2023
301
138
Nevils, GA USA
I have our EmpireTech NVR8CH-8P-2AI setup and and working and it does display already-networked cameras OK.
We have a Loryta 4mp Starlight about 80' from the NVR (it was powered via a remote POE then data via a remote router in switch mode).
It is just now directly connected via a CAT7 cable - and connected to Port 1 of the NVR8CH-8P-2AI.
The NVR8CH-8P-2AI doesn't recognize it at all.
Note: The cable is a straight-thru type and tests fine for all 8 leads.
Where should I start looking for the problem, please?
Thanks.
It probably has an IP from your LAN. Put it back on the LAN temporarily, login to it, change IP to 10.1.1.65 (should be your NVR #1 port) immediately unplug it and plug back in into NVR #1 port
Check on NVR camera registration page to verify I’m right , or better show a pic of that page
Can you login to the NVR via the web UI?
Much better than the machine interface
Thanks!
Question: Would removing it from the LAN - DHCP Server list - accomplish the same thing?
Unless you changed it, should be 192.168.1.108
Not sure what model but under the trp door on the camera there is a little bitty black reset button. Have it plugged into the NVR and hold it down for 30 seconds and let go
Yes, should be a compartment on the eyeball case to open with two retained screws
Yup. Unmounted the camera, killed the black & white spider, opened the compartment, then leaned on the microswitch for 30 seconds.
Tried 2x, in case I didn't have good contact with the micro-switch. Nada.
I noticed that it was in "Not Auto Connected" and deleted it there. Tried again ... Nada.
PoE shows, variously, 1.7 - 2.0W on that port.
It was connected to the NVR port at the time?
Is it showing on the web gui camera registration page at all? What IP?
Shouldn’t have killed the spider
  • Haha
Reactions: observant1
When connected to the NVR a new or reset Dahua camera will assume the login /pass of the admin NVR btw
It doesn't appear to be showing anywere. Not in Remote Device, etc.
I did just connect my newest EmpireTech camera and it works (see pic of PoE page).
Interestingly, adding the second camera caused the wattage to the first to increase.
You need to login to the NVR web GUI and go to this page or something like it
Reactions: Flintstone61
Don't know the age of the camera but my guess is that it is older and is looking to use admin as the password. I would either remove the camera from your POE NVR and connect to POE switch or connect using 12v and ethernet to your router/hub/switch. and log in using admin admin.. Or just change the password in the cameras device config area to match admin admin and just make sure to change it because you don't want to leave default like that.. Anyway if you did put in switch on your network using IP config you can modify password there by logging in to it. Then it will prompt you to change the password. Make same as you use on your NVRs cameras.. THen you can install back to the NVR.. My guess is that installing the other cameras didn't increase the other cameras wattage it was caused by the cameras watt needs either change in light conditions and or other factors depending on the cameras options.. Anyway my guess is that the camera needs you to setup with old admin admin if you can't either Initialize it with that function in the NVR or if you don't want to just add it using admin as the password until you change the password after a connection to the cameras WebUI at some point in the future.. Just make sure if you do add it by changing the password in the NVRs device area clicking on the pencil and changing the password there. YOu will want to make sure you change the password soon after so it don't got changed later and forget to make the update yet again in the cameras setup area on the NVR. Not all OEMs act like Dahua cameras on a Dahua or other OEM NVRs..
Yeah easy test in that page that bigredfish just said you should go to. CLick the pencil and put admin for password if it changes to Green that was the issue. Then click the e to log into the camera and it will prompt you to change the password then change password and save, exit the cameras WebUI, then back at that page again click pencil again and update the password to what you just setup and it should remain on your NVR from there on..
Edited version
The age of the camera is unclear, but it seems likely to be older and may still use "admin" as the default password. To troubleshoot, you can remove the camera from your PoE NVR and connect it to a PoE switch or use a 12V power supply along with an Ethernet connection to your router, hub, or switch. Once connected, try logging in using the credentials "admin" for both the username and password. Alternatively, you can change the password in the camera's device configuration area to "admin" for both fields temporarily, ensuring to update it later for security reasons. Leaving the default credentials is not recommended.
If the camera is connected to a network switch, you can use an IP configuration tool to modify the password. Logging into the camera through the tool will prompt you to change the default password. Ensure you set the same password as used for your NVR's other cameras to maintain consistency. After updating the password, reinstall the camera on the NVR.
The issue with other cameras' wattage increasing is unlikely related to adding new cameras but may be caused by changes in light conditions or other settings specific to the cameras. If the camera requires the default "admin" credentials to initialize, this can often be managed directly through the NVR interface. If you prefer, add the camera with "admin" as the password, then access the camera's WebUI later to update the credentials.
To update the password through the NVR, go to the device setup page, click the pencil icon, and input "admin" for the password. If the status changes to green, this indicates the issue is resolved. Then, click the "e" icon to log into the camera, where you'll be prompted to change the password. After saving the new password and exiting the WebUI, return to the NVR setup page, click the pencil icon again, and update the stored password to match the new one. This ensures the camera remains properly connected to the NVR.
Keep in mind that not all OEMs behave like Dahua cameras when used with Dahua or other OEM NVRs, so certain steps may vary depending on the manufacturer.
I'll give that a try, thanks.
