Hey guys. I have 2 cameras.
Camera 1 has the CBX firmware and Camera 2 the @whoslooking region hack (thanks again)
Everything worked fine and i used the EZVIZ App with them.
Than i changed the IP of the Camera in my LAN. Since then the EZVIZ7 is not working any more. It said "offline". I changed the IP-Address back to the original one but this did not work either.
Than i deleted the cameras from ezviz and tried to activate them again... not working.
What did i try.
I tried:
- adding the camera with the ezviz app to my ezviz account and with the ivms 4500.
- adding the camera with different browsers.
- adding the camera with a macbook instead of pc
- it with resetted the settings of the camera
- reflashing the firmware using TFTP
- to create a new ezviz account
I can see the camera when i click on "Add automaticly"
when i click on manual this error appears: "The device is offline. No search result is found"
NEVER CHANGE THE IP OF THE CAMERA
Did anybody have the same problem and can help me? i have no idea how to fix it
What did i try.
I tried:
