- Sep 14, 2015
- 1,279
- 4,259
Can you guess what they were doing with long pole being held out the window?
They didn't know how far of a walk it would be, so they decided to improvise with the pole. At the end of the dirt road is a house that is currently empty. Distance from the nearest water source is 1,395 feet (425 meters). They were down there for almost an hour. Maybe some type of training is my best guess.Seems like if all they were doing is measuring distance, it would have been easier to go on foot. How long is that road?
Probably also testing if they can get the truck in and out I guess.
Makes sense to me </end sarcasm>. Tie up an expensive fire truck and 3 municipal employees, unavailable to respond to actual fire fighting/rescue while they are tied up performing land surveying without proper instruments or training to do so when a contracted land surveyor could do it more accurately and probably quicker and cheaper......it's call "making work" to justify personnel budgets and departmental expenses, especially when a union is involved.That was probably why they were down there for so long. Mapping out the increase in size of that property.
That property is fairly large for this area. It is an old farm that is around 8 or 10 acres in size. It has a well for water and septic tank for sewage. It has been empty for several months now.In San Jose the fire department has been tasked with measuring unpaved roads for two reasons. They then compare that reading to the Google Maps value and to the truck's odometer.
They get funds based on the truck's odometer and they are concerned that the tuck's odometer is not reading correctly on unpaved roads.
The second reason is, due to the active faults in the area, the length of roads has been changing with the fault movements. On paved roads it is easy to see the offsets and can be easily measured. But on unpaved roads you rarely can see the offsets. This will help with getting additional funding based on projections of increased road lengths and therefore the need for additional fuel.
As a side benefit, these measurements can assist the taxing authorities with increasing the tax based on the increase in the size of the property and the length the fire, police, and ambulance have to travel. That was probably why they were down there for so long. Mapping out the increase in size of that property.
Amen.....I've put a few miles on one of these ==>> Rolatape 32-400 Professional 400 Series Measuring WheelSeems like someone is a bit ill prepared and has never used a rolling wheel to measure any distance. The one they are using is made for hard surfaces and usually very short distances. If anyone had half a clue of what they were doing, they would have used one of these:
I enjoyed your reply!1. Tonyr, I love traffic systems so thats cool that you did that forever. Side Note, I just finished installing a GPS/Radio Based Traffic Pre-emptive system in our fire trucks, and the city is installing the street signal side obviously but it has made an incredible difference in the area of safety responding through an intersection. Being cloud based, we have very specific control on the zones for changing the lights etc and it even incorporates our trucks turn signals for direction of travel.
IMO, no.You'd have thought they'd carry bolt cutters.
Am I being too sensible here?
The woman firefighter used pliers to open up one of the chain's links. Then on the way out, they used a sledgehammer to push that link back together.You'd have thought they'd carry bolt cutters.
I like your version better.Actually, it looks like the chain was nailed to the post, and they were removing the nail enough to remove the chain. Most chains that people would use to secure gates with would be welded and cannot be pried apart.
