firmware in a vm
kcinick
Aug 29, 2016
15
do anyone get the firmware of a hikvision nvr running on a vm, is that even posible?
no the cameras run arm architecture, not x86.. and its going to be hardware agnostic, its going to bomb hard if you try to emulate a camera environment..
why would you want to do such a thing?
running the nvr software, not the camara, on a x86, its a lot more powerfull than an arm procesor, using QEMU to emulate the ARM processor, then running the linux distro (i thinks is a linux) that comes with the nvr on a vm, why do i wanna do that? coz i have a pcnvr (from hikvision) running on a windows vm, i would like to run the real software, the one that accept any camera, not only hikvision ones, and without buying a hardware nvr...
they have hardware encoders and decoders on them though, your not emulating them.
nobody's done it, good luck
my Dahua NVR has hardware h264 encoders and decoders that the NVR software has to load up.. Ive ran it manually and the very first thing it does is check and list the hardware capabilities, and it's got quite a bit of dependencies, from encoders/decoders, to watchdogs, to framebuffers for output and GPIO access, there's alot of specific kernel modules running on my NVR and none of it will work if they are not loaded.
I was going to have a stab at setting up QEMU as a potential way to mess with the NVR firmware - wouldn't it be great to have a debugger, instead of poring over disassembled code and chucking in a mod only to see it bomb?
But I didn't get very far, decided it was maybe a bit ambitious.
i386 NVR image (https://www.hikvision.com/en/products/IP-Products/Network-Video-Recorders/Ultra-Series/). The 6a6e1876-202a-4773-ae76-b883b2a7ee3b.zip give me a digicap.iav file, that I cant boot from ...
With Hikvision FIRMWARE TOOLS - change language, extract files and create own firmware I splited the iav (renamed to .dav), but no ideia what do now...
bzImage
grub.cfg
grubx64.efi
guirc.tar.gz
gui_res.tar.gz
hi3536_slave.tar.gz
new_10.bin
RSA
start.sh
webs.tar.gz
EDIT: Dahua has some x86 linux NVRs (Index of /Firmware/Rejestratory/DSS/), but I dont know that do with the .BIN files
#NVR #x86 #vmware #virtual machine
bzImage
grub.cfg
grubx64.efi
guirc.tar.gz
gui_res.tar.gz
hi3536_slave.tar.gz
new_10.bin
RSA
start.sh
webs.tar.gz
Did somebody tried this idea?, maybe you can use GitHub - firmadyne/firmadyne: Platform for emulation and dynamic analysis of Linux-based firmware
Reactions: sunny0101786
