Firmware needed for MC800S - Does anybody have it?
lucato
Dec 3, 2020
29
5
Brazil
Hi folks, I need the .bin file for that camera image below which uses the firmware MC800S_AF_V3-A_STARC-H5 V3.2.2.4 build 2023-04-11 09:10:14 or I need a NEWER one. Does anybody have it?
Here is the camera I bought at Aliexpress:
thanks and have a great day.
Hi, did you ever find this firmware version? I would like to restore to this version after upgrading to V3.3.0.1, which does not support PTZ functions.
However FYI as an intermediate working solution I am using Vikylin firmware "PTZ-4840X-IS-Firmware.bin", which seems to be better, except I lost a little bit of wide-angle zoom
FYI my camera model is Asecam 8MP 4K 30X zoom PTZ
Hi there. I didn't find a newer for 3.2.2.4 I had. Actually, I didn't get to test the 3.3.0.1 because by mistake I screw my camera firmware. I had updated the firmware to MC800S_AF_V2 instead of V3, where V2 is only for non PTZ cameras I think, and now the camera doesn't accept to upload the V3 to update again! I'll have to disassembly from the pole and the camera to see if I get to fix in some way. So, watch out to not use different Versions and check the correct firmware name is in your camera at the VERSION information. Here is the link to the firmware (V3): or also others: - Not sure if fits for your camera model. As I said, check the exact name and version of your firmware. Good luck!
Also try to contact the seller you bought it from to provide you the firmware. Mine, didn't give a sh** to its customers!
Thx for reply. Do you still have the 3.2.2.4 file? I really would like to have it since this is the best version for me. Unfortunately I did not keep it... I can give you an upload location if needed.
I contacted the supplier (Asecam) but no response from them >:-(
I installed 3.3.0.1 but it does not provide PTZ functionality. The version I am now running is called "firmware_MC800S_V103_AF-RTMP-A-DH-H5_V3.2.4.5_YSSD_MC800S-YSSD2_V3_202308241041". It works fine but does not give me the full wide-angle zoom.
Good luck with trying to playback a V3 firmware!
Nope, once it came with the camera and I had no way to export it before updating, anyway in the link above you get the 3.2.2.2. Did you get do find your 3.2.2.4?
I also bought a Vikylin 18x PTZ on Aliexpress, but the human autotrack does not work correctly. When it is detecting a human, the camera keeps turning 180 degrees. I asked the seller for an updated FW and I got one, really fast!. Unfortunately it still does not work. I also asked Vikylin and keep asking they can check with teamviewer....Not secure for me
My FW versions are also all MC800s versions, but I have PTZ? I got this one from the seller: MC800S_V103_AF-RTMP-A-H5_V3.3.2.0_YSSD_MC800S-183-YSSD2_V103_202407301540. Maybe it will work?
I really can't tell the differences between all those versions and the FW is hard to find on internet
the "official" PTZ-4818X-IS-Firmware does not work for me (won't be loaded in camera)
Hi,
do you still have the firmware MC800S_V103_AF-RTMP-A-H5_V3.3.2.0_YSSD_MC800S-183-YSSD2_V103_202407301540? I am searching for it. Could you please attache it?
Thanks.
Best regards!
I tried this one which seems to be a more recent version, but if I remember correctly I could not install as my camera (it is PTZ) did not accept it: MC800S_V103_AF-RTMP-A-H5_V3.3.2.0_YSSD_MC800S-LH-YSSD2_V103_202408071641. I will upload it as a reply to the next post below.
Hi,
Thanks.
Best regards!
See attached. I could not install it but it might serve you better.
Great, thanks, didn´t test it yet, will try tommorow.
But do you still have the version MC800S_V103_AF-RTMP-A-H5_V3.3.2.0_YSSD_MC800S-183-YSSD2_V103_202407301540.
I have also a ptz-cam and had to replace the camera-module because of heat-damage. I tried different firmwares from anjvision-site, but none gave me the full zoom and the version with 183 in the name is not downloadable. I hope that the firmware with 183 in the name works with my zoom-module that is named DS-183... Could you please share this version too?
O.k just tried the MC800S_V103_AF-RTMP-A-H5_V3.3.2.0_YSSD_MC800S-LH-YSSD2_V103_202408071641.bin. Also the same Problem with the limited zoom.
The only thing with 183 in the name is this version which I recently received and used for a 5X zoom bullet camera. Let me know if you need this: firmware_MC800G_V101_AF-RTMP-GB-A-H5_V3.4.2.2_YSSD_MC800G-WIFI-183-YSSD2_V101_202506110942.bin
In the meantime, I am still looking for a version that looks like this: MC800S_AF_V3-A_STARC-H5 V3.2.2.4. Only this version gives me full wide-angle zoom on my PTZ zoom. Should anyone have this version, please DM.
The MC800G does not work for mycamera.
I can offer this one that looks like MC800S_AF_V3-A_STARC-H5 V3.2.2.4
firmware_MC800S_V3_AF-RTMP-A-DH-H5_V3.2.2.4_YSSD_MC800S-QF-YSSD2_V3_202303301038
This worked great for me thanks! Zoom range still indicates 1X-30X but I recovered approx. 50% more wide-angle. I may have lost a bit at the tele but that is not important for me.
great to hear.
I know/guess
AF =autofocus
RTMP=streaming-option
A=?
DH=supports Dahua protocol
H5=html5-->works with every browser
V3.2.2.4=version
YSSD=?, maybe option sd/usb
MC800S=ip cam module
QF=i guess zoom module, also possible 183, LH, ...
YSSD2=?, maybe option sd/usb
V3=version ip cam/chip module
202303301038=date
Maybe, if you have also the ys183-zoom module, with the Firmware MC800S_V103_AF-RTMP-A-H5_V3.3.2.0_YSSD_MC800S-183-YSSD2_V103_202407301540, as from ElRolo postet, it would be perfect.
Do you have any manuals for presets to adjust or calibrate the zoom module?
