Foscam FI9821W V2 Firmware Update - v2.11.2.8 - Apr 23, 2014
Mike
Staff member
Mar 9, 2014
3,061
3,094
New York
Update on April 23, 2014
Firmware version: 2.11.2.8
Improvements:
  1. Protects all characters involved in code decryption, including username and password;
  2. Fixed a bug where visitors and operators could browse the settings interface if the plug-in was not installed.
The procedure for upgrading to the latest version is as follows (Warning: FI9821W V2 Only)
  1. Firstly determine which firmware version currently exists on your FI9821W V2 by checking under Settings > Device Status. You are looking for the "App Firmware Version"
  2. If you have App Firmware Version 2.11.1.6 proceed to download and install the latest version 2.11.2.8 here.
  3. If you have App Firmware Version 1.11.1.18 first upgrade to 2.11.1.6 here, and then to thelatest version 2.11.2.8 here.
  4. If you have App Firmware Version 1.11.1.16, first upgrade to 1.11.1.18 here, then to 2.11.1.6 here, and finally to the latest version 2.11.2.8 here.
  5. If you have App Firmware Version 1.11.1.15, first upgrade to 1.11.1.16 here, then to 1.11.1.18 here, then to 2.11.1.6 here, and finally to the latest version 2.11.2.8 here.
  6. Please follow the instructions contained in "Upgrade Guidance for the FI9821W V2.pdf" included in each download. Failure to install the firmware correctly could result in bricking your camera. If you are unsure on how to proceed, please stop immediately and contact us. Please note that this firmware update is for the FI9821W V2 only. If you are not sure which camera you have, stop immediately and contact us.
Old firmware below
The Foscam FI9821W V2 camera had a firmware update today. The latest firmware is now 2.11.1.6.
New features added:
  1. Supports IE11;
  2. Supports playback of all recording functions;
  3. Prompts user to revise the default user/pass credentials upon first login;
  4. Supports new pan/tilt cruise function with scheduling;
  5. Supports configuring dwell time at each preset when cruising;
  6. Supports turning IR LEDs on/off according to a schedule;
  7. Indicates password security level when changing/setting passwords;
  8. Supports frame pumping for scheduled recordings to SD card;
  9. Supports manual recordings to SD card;
  10. Supports PC beep when motion detected;
  11. Supports uploading scheduled recordings to FTP server (without audio);
  12. Supports hidden SSID.
Improvements:
  1. Extended the Max alarm recording time to 5 min;
  2. Enhanced the SD card storage feature.
  2. If you have App Firmware Version 1.11.1.18 proceed to download and install the latest version 2.11.1.6 here
  3. If you have App Firmware Version 1.11.1.16, first upgrade to 1.11.1.18 here and then to the latest version 2.11.1.6 here.
  4. If you have App Firmware Version 1.11.1.15, first upgrade to 1.11.1.16 here, then to 1.11.1.18 here and then finally to the latest version 2.11.1.6 here.
  5. Please follow carefully the instructions contained in "Upgrade Guidance for FI9821W V2.pdf" included in each download. Failure to install the firmware correctly could result in bricking your camera. If you are unsure on how to proceed, please ask for help on the forum!
Hi guys, I have a older firmware 2.11.1.10
I dont see it on your list above. Which upgrade should I download for what I have? Thank you for the help.
