M mbh Getting the hang of it May 9, 2023 94 42 CA Jun 19, 2024 #1 Hello, I have changed all my settings to the following, based on what @wittaj taught me in another thread: H264 8192 bitrate CBR 15FPS 15 iframes My questions is, I did not change anything on my sub stream's. Is that correct or is there something I should have changed? Thank you..
wittaj IPCT Contributor Apr 28, 2019 34,534 65,751 USA Jun 19, 2024 #2 Most will have the substream FPS and iframe match the mainstream. Reactions: bigredfish
M mbh Getting the hang of it May 9, 2023 94 42 CA Jun 19, 2024 #3 @wittaj This is what mine looks like - should while you're looking, is the resolution okay on the substream?
bigredfish IPCT+ Member Sep 5, 2016 39,401 87,487 The Swamp Jun 19, 2024 #4 Shouldn’t really matter much but I generally run 15/15 fps and Iframe at 1024
M mbh Getting the hang of it May 9, 2023 94 42 CA Jun 19, 2024 #5 bigredfish said: Shouldn’t really matter much but I generally run 15/15 fps and Iframe at 1024 Click to expand... Okay great, I will adjust mine accordingly, thank you! Reactions: bigredfish
