Thanks!You won't see any benefit, your performance would be worse... use Intel HD and enable hardware acceleration... what is your load now?
something is set incorrectly...you should be at about 15 percent (Assuming the foscams are 1080p, if they are lower even less)...Thanks!
At the moment I am hovering around 35% +-2%
Yes, I followed to config guide. The 4 Dahua's are running @ 3mp.something is set incorrectly...you should be at about 15 percent (Assuming the foscams are 1080p, if they are lower even less)...
Have you enabled direct to disk and HA for all cams?
i understand that the dahuas are 3mp..you dont state the foscam resolution..Yes, I followed to config guide. The 4 Dahua's are running @ 3mp.
check cpu by using the blue iris mobile app, or direct via local monitor...My apologies, my brain was fried from running cables in the attic in 95 degree weather.
There are actually only 3 Wireless Foscams, and they are old, hence 640 X 480 resolution I believe.
I will confirm all my settings when I get home tonight. I am running BITools, which is where I'm getting my CPU utilization.
When home I use remote desktop to access the server, otherwise I log into the web server.
I did notice that this morning, I am running around 20% +/- 3%
When I posted last night, my outdoor cameras were in IR mode (don't know if that impacts cpu)
Thank you for your input, I appreciate it.
George
