Hello! New to this forum and amateur with cameras.
I've used BlueIris for 9 IP cameras for about six years using a mix of bullets (Hikvision rebranded Lorex/Swann) and wifi (Samsung, Amcrest). I am moving to a new house and looking to start from scratch using Dahua cameras while contining to use BlueIris.
Here are the products I am considering. Most locations will have lamps nearby which addresses the concern for low-light quality.
8x IPC-HDW5831R-ZE IPC-HDW5831R-ZE
2x IPC-K35S IPC-K35S | Dahua Technology
8x PFA130-E PFA130-E
The house is prewired with CAT6 for the 8 wired cameras. The 2 wireless will be for indoors and float around the house. So all I need to do for the most part is connect and position the cameras then configure.
My biggest question right now is using the proper junction box. I see that the PFA137 is the suggested accessory, but according to the following link and the trim plates on my walls, the PFA130-E might be the appropriate choice http://in.dahuasecurity.com/download/Accessory_Selection_201712294.pdf
I've never used junction boxes before so should this work? The picture below will have a camera on the left wall, a camera on top, and a flood light bottom right. The left camera will almost have to be angled 45 degrees to see the side of the house.
I heard Andy @EMPIRETECANDY is the go to guy for these cameras too, so I may be reaching out to him.
Thanks!
Thanks!
