Hello. I just bought IP Cam Mosvitec ip400-fo20v0622
It looks like OEM Chinise cam.
Mosvitec have their website but support doesn't answer
The main problem was that cam has admin password and there is no reset button
I tried all the possible default passes - no result
As soon as it looks like Hikvision I followed the instruction disassembled it, found UART pins and succesfully conneted.
I get the following info:
ip400-fo20v0622fg4_16nr_alh0l0a0t0q0_k300035685_v1.0.5.220312_r1tmsemi
tms1102nlFirmwareVersion:
FG4_16NR_ALH0L0A0T0Q0_K300035685_V1.0.5.220312_R1CPU:
FUHAN865xMSensor:
gc4653_mipiU-Boot 2010.06-dirty (Oct 30 2021 - 10:06:31)
Markdown (GitHub flavored):
bootstrap: 0x000000000000-0x000000040000
uboot-env: 0x000000040000-0x000000050000
uboot: 0x000000050000-0x000000090000
kernel: 0x000000090000-0x000000390000
app: 0x000000390000-0x000000e90000
var: 0x000000e90000-0x000000f90000
param: 0x000000f90000-0x000001000000
U-Boot> printenv
bootargs=console=ttyS0,115200 root=/dev/ram0 mem=64M mtdparts=spi0.0:256k(bootstrap),64k(uboot-env),256k(uboot),3M(kernel),11M(app),1M(var),448K(param)
bootcmd=sf probe 0; sf read 0xA1000000 0x90000 0x300000; bootm
bootdelay=1
baudrate=115200
ethaddr=2C:6F:51:0D:69:0A
ipaddr=192.168.1.168
serverip=192.168.1.1
phymode=RMII
ethact=FH EMAC
stdin=serial
stdout=serial
stderr=serial
Environment size: 380/65532 bytes
During my tests I run the following command as per ChatGPT suggestion
setenv bootargs init=/bin/sh
boot
Sо now boot proccess stops at:
starting pid 92, tty '': '/etc/init.d/rcS'
[RCS]: /etc/init.d/S01udev
Starting udev: [ OK ]
[RCS]: /etc/init.d/S03network
mac: 00:30:1b:3c:72:bb
[RCS]: /etc/init.d/S99longse
squashfs: SQUASHFS error: unable to read id index table
mount: mounting /dev/mtdblock4 on /opt/app/ failed: Invalid argument
grep: /var/etc/update: No such file or directory
sh: 1: unknown operand
app not exist
starting pid 215, tty '/dev/ttyS0': '/bin/login'
(none) login: /etc/init.d/S99longse: line 35: /var/bin/startmini.sh: not found
So the cam doesn't start correctly.
Questions:
1 - Would you be so kind to help me identify the Cam to get the firmware.
2 - is it possible to recover initial settings by UART commands
3 - how to clear the admin's password
Thank you in advance.
