Help needed with Lorex LNB8105X -C-MU
Apr 29, 2023
4
1
Manchester UK
Hi all
I'm a newbie to this forum
I'm just wounding if anyone knows how to access the casing of a Lorex LNB8105x-C-MU
i have a camera that's had its wiring cut off and i am hopefully going try to rewire it also the plug has become detached from the circuit board and the only way to reconnect the plug is to open the camera body
I've tried to access the camera via the removable case ports but i can not see how to open the main body to access inside theres no visible screws i have added some pictures
Can anybody help me out here
You have to pop the black plastic cover off the front of the camera then you can unscrew everything and pull out through the front. A little tricky to remove but they do come off and pops right back on.
Reactions: TonyR
