Hi Everybody
Thanks to you all, I have been able to select, buy and install the security cameras at my home. I have a dedicated PC serving as the NVR and Blue Iris as the software.
My cameras are all Uniview :-
3 off 4 MP cameras with 1/1.8" sensors and
5 off 5 MP cameras with 1/2.8" sensors (couldn't get 2 MP cameras with 1/2.8" sensor)
With all wrong settings on my NVR, my computer was using between 30% and 100% CPU. I then read some of the documents available on the wiki on this forum and this morning changed some of the basic settings for the cameras with all cameras now having :-
Direct-to-Disk recording and
Both Main and Sub stream recording
My CPU usage has come down from over 90% to between 3% and 4% - great!
I am still not convinced that my settings are right, and I don't know any better to make a judgement call on what they should be like. I am making available the screenshots of the following settings for one of my cameras (the intent being that all of them would pretty much have the same settings) with the hope that some of you might be able to suggest better settings than most of the default settings that I have. I have, as such not changed much in the settings at all.
These are :-
1. Uniview Camera Video Streams Settings.jpg - showing main, sub1 and sub2 stream settings (from the camera web interface)
2. Blue Iris General Camera Settings.jpg - showing Blue Iris General Settings (from the Blue Iris interface)
3. Blue Iris Record Settings.jpg - showing Blue Iris General Settings (from the Blue Iris interface)
4. Blue Iris Video Camera Settings.jpg - showing Blue Iris Video Settings (from the Blue Iris interface)
5. Blue Iris Trigger And Motion Sensor Camera Settings.jpg - showing Blue Iris Trigger & Motion Sensor Settings (from the Blue Iris interface)
Also, I have tested the Pushover app and it seems to work almost instantaneously and flawlessly - no issues at all. I also set up an email notification for when I am overseas and may not have access to mobile data, just in case, and that too seems to work OK.
The only issue was that at nighttime, when cars go past my house with headlights on, it seems to activate the motion sensor trigger and I get a notification that I don't need - this doesn't happen in the daytime with the same settings.
The street is at least 5 meters away from my plot boundary and has been excluded from the monitored zone and I tried to increase the contrast to from 25 to 48 but that doesn't seem to help either. The object size was set to 100. Is there any other setting jor option available to address this issue.
The recording in the setting currently shows 'Triggered' but its intended to be continuous when other parameters have been correctly setup to minimize on recording when the other relevant settings may not be ideal.
Best regards
Deepak
These are :-
Best regards
Deepak
