Paste that RTSP URL using the "Insert" => "Code" option in the menu above the post window; "insert" is to the right of the smiley face emoticon.Ok, I think I have a way forward. I was able to access the RTSP stream coming out of the camera with VLC. Now I need to configure BI to accept that stream. Any guide on how to do that?
I have a Annke NVR system that I purchased on Amazon in 2018. It is an N481Y system that came with 4 bullet cameras, I believe they are model I31BY cameras. I am setting up a new camera system using Blue Iris, ans would like to re use these cameras if possible. I have successfully connected a new Reolink camera to the BI system, so I know it can be done. The issue I'm having is I cannot connect to the Annke cameras, other than through the NVR. I'm not sure how to find their ip address, or how to change it like I did with the Reolink camera. Any help would be greatly appreciated.
Then myself, wittaj or someone can suggest how to fit into BI's "video" => "configure".
rtsp://user:password@192.168.1.92:554/Streaming/Channels/101
I have the manual, it's 12 8.5x11 sheets. I can scan them, but they would be out of order, I can take pics, but that would be a bit of a pain. What specifically do you want?Hi @nukeworker
Got a spec sheet for this kit ?
I've been looking for the specs / data sheet online and have been unable to find it.
Hi @nukeworker
That's a Hikvision URL!this is the rtsp URL for one of the camerasCode:rtsp:/user:password@192.168.1.92:554/Streaming/Channels/101
You did it. Yay!!That's a Hikvision URL!
In BI, in the drop-down select make as "Hikvision" as make and as model select "DS-2CDxxx RTSP" or below that, the "DS-2CD6362/6716/7204/7608, etc."
Is it working?You did it. Yay!!
Not sure what your asking, but I am seeing the camera stream passed from the NVR. The NVR is still up and running. I would like to get rid of the NVR, but I can work with this for now.Is that from a cam or the NVR?
The IP you used in the URL that works...is it the NVR's LAN IP?Not sure what your asking, but I am seeing the camera stream passed from the NVR. The NVR is still up and running. I would like to get rid of the NVR, but I can work with this for now.
OK, you create a new cam, put in ALL the identical info (IP, username, password, make/model) but....in the drop-down select CAM 2 and OK, then repeat for CAM 3, and so on.NVR Lan IP
What does that do for me? Is it a faster way to add them? Also, when I add a new camera, I have to give it a different nameOK, you create a new cam, put in ALL the identical info (IP, username, password, make/model) but....in the drop-down select CAM 2 and OK, then repeat for CAM 3, and so on.
Nevermind, I figured out what you were sayingWhat does that do for me? Is it a faster way to add them? Also, when I add a new camera, I have to give it a different name
You can also copy the first working camera to a new camera and just select the new cam # in the drop-down as mentioned toward the bottom of post #4 by wittaj.Nevermind, I figured out what you were saying
