I made some updates to my sky rig which involved turning the whole thing 90*. In doing so it changed the scenes and I am seeing artifacts I didn't see before, possibly due to lighting. Any thoughts on how to troubleshoot if it's a setting issue or a hardware issue?
I am seeing this with three of them, and it just happens that three of them were refurbs, so maybe it was an existing issue, but not sure. I thought maybe it was BLC, but the issues persisted with the camera when moved to a new scene.
BLC is ON.
All other settings are as expected.
I am seeing no issues with this camera. It is what originally pointed West. I see no issues looking back at those captures.
If you look at my roof, the houses across the street, and the tree line you can see artifacts in the left camera. This camera was originally pointed North. The capture below this one is from when it was pointed North.
You can see how the left lens is very heavy with dots and the right side shows only a few stars.
In the right lens you can see artifacts all of the way down through the tree line and onto the street. This likely had artifacts when it was originally pointed South. The camera at the top that was originally pointed this direction had no issues.
This is when the camera was pointed South, much like the North capture, there are a lot of dots in the right lens but not many stars in the left lens past the splice.
This one is more difficult to see, but there are some on the house in the lower right. Looking back at when this one was mounted facing East, and actually looking for them, there were some visible but a bit more difficult to see because of the lighting in the scene.
BLC is ON.
