fenderman
Staff member
- Mar 9, 2014
- 36,891
- 21,419
There is no issue with bi5. Perform a clean install. Preferably a clean windows install using the ms media creation tool. I also encourage you to get an nvr. You will come running back to blue iris. You will also realize that nvrs have issues as well. Just search the forum and see for yourself. Most blue iris issues are user created. Start with a clean windows installOkay, I disabled every camera but one. CPU usage dropped down to below 15%. It stays like that for a minute or two then everything drops to 0% (CPU and RAM) then the system crashes.
Now I can't even get the GUI to open. I'll probably re-install BI again. (I believe my license for BI4 is still good, I may go that route).
The cameras and Blue Iris machine are on their own subnet. 7 of the cameras are Hikvision. Two are Lorex with limited adjustability.
I have my Windows 10 machine set up to record directly to a 1TB M.2 SATA drive. I have that adjusted to record for 5 days or 800Gb then move over to two 4TB WD Purple drives. Everything in on this machine.
