Was hoping I could get another set of eyes on this. I have 2 duplicate systems, i7-9700 with 16GB ram and Intel 630 Graphics, the 'bad' system has 24 cams, and I have a 'good' system running 26 cams. Bad version = 5.4.9.10 (7/18/2021), Good version = 5.3.3.12 (10/26/2020)
The trouble systems has been pegged at 100% CPU since it was set up. I've gone through twice now so it seems that HA Decode got turned off on the bad system somehow, has anyone seen that before?
I'll list what I've done here
Bad system
Good system
- Direct to disc recording
- Intel HA decode
- All cams at 15FPS
- Running as a service
- Preview Framrate is 1FPS
- Video scaling=Fast
- Encoder Preset=ultrafast
- Sub streams
- Video overlays
- Limit decoding unless required
- Should I try going back to v4? I feel like some of my older setups have been a little more stable...
- As you can see the bitrate and MP/s is lower on the 'bad' system but CPU and RAM are almost 50% higher.
- One thing I thought was interesting was that video decode is much higher on the 'bad' system, maybe that should point me in a direction?
- There aren't any outlier cams in regards to FPS/bitrate
- Both systems are continuously recording and have motion detection
- I can look at some of the other options but academically, I'd like to figure out why these behave differently, with everything I've looked at I'm wondering if it's a 'bad processor' that just isn't running as smoothly as the other?
Bad system
Good system
