- Jun 18, 2016
- 21
- 1
So I have a Hikvision 7716NI-SP/16 NVR (firmware v3.4.5) with 9 Hik cameras all configured and port forwarding setup. The cameras have several smart events (tripwires) setup and linked to notify Surveillance Center.
Until recently, I'd been using the Hikvision iVMS-4500 iOS app with my NVR manually added using its static IP and port information. At home or remotely, I was able to play live video, playback recorded video, and receive push notifications (after enabling the Alarm Notifications for my NVR in the app), etc. There was one issue in that I'd have to click on the actual notification to be brought into the app and see it in the alarm list, but that's a different issue
Recently I tried out the (newer?) Hik-Connect iOS app, and like some of the new features and UI quite a bit. However, after manually adding my NVR, I can't seem to find any way to enable push alerts (what it calls Messages) for it. In the Help for "Enabling/Disabling Alarm Notifications" it mentions going into Settings for the device where there is a switch to control this. However, I don't see the switch for my manually added NVR.
Now if I go and add register and enable the NVR through their Hik-Connect service, I do see a switch for enabling Alarm notifications (which presumably would work). However, I'd like to avoid using that route to connect.
So I guess my question is this. Is it not possible to configure and receive push notifications through the Hik-Connect app without connecting the NVR through the Hik-Connect service ?
It seems like it should be possible (at least it was using iVMS-4500), so I'd love to hear from anyone with a similar configuration. Really any input is welcome.
Thanks!
Thanks!
