How can I Convert 6GB .BVR to MP4?
emersonvier
Apr 29, 2017
124
39
IL
Hi all I need your help here how can I Convert 6GB .BVR to MP4?
Sooy but I am learning now I need to have small files, so I change the config to have 1GB Files.
That is not where you limit the file size, you inadvertently limited the size of the new folder to 1 GB, and since it set to delete you only have a few minutes of recorded video. Set it back to 95% you're available free space. the file size limit is set in the record tab of each camera
Reactions: emersonvier
You setting are completely messed up.
Use the correct folder names for your folders, do not change the names, just the drive letters.
c:\BlueIris\db
C:\BlueIris\New
c:\BlueIris\Stored
c:\BlueIris\Alerts
You set the total files size for the folder in the system options.
You set the controlling files size for a camera in the camera configurations
Thank you for your tips.
Please see my new setup, is it correct now.
:goodpost:
Look under "Clip folders" in help section. It explains it very well and you will want to redo all your settings again.
I do not use clip age. I just use space. The allocated space fills up then get deleted as needed.
General space advice, allocate only 95% of a large drive space tp BI. Never allocate 100% of a drive to BI.
If New and Stored are in the same drive then I’d personally not bother moving to Stored.
You have also set Stored to move to Stored?
Also interested in why you need to convert the clips to MP4
I will change my settings to move to my NAS.
My neighbor was robbed, so I will provide the video for him.
Reactions: Natey2
So you just need to export the clips of interest not set it up to do it all the time?
I Have 6 hours video = around 6GB, I try to convert this big files did not work.
