How is a VPN more secure than port forwarding?
Clucky
Mar 28, 2024
91
32
PA
Correct me if I'm wrong, but don't VPNs require port forwarding as well? Can't you just set a strong password for Blue Iris instead of having to go through all the challenges with using a smart phone + VPN + Blue Iris? The app is already problematic enough without the VPN (sometimes the app opens and doesn't automatically connect)
Well set up port forwarding and watch how quickly you start having attempts at it.
In layman's terms, opening a port for a VPN service is much different than opening a port for an unsecure device like a camera or NVR or straight to BI.
In fact, by default routers and computers have ports open like 22 (SSH for secure remote access), 25 (SMTP for email), 80 (HTTP for web browsing), and 443 (HTTPS for secure web browsing), etc. are common open ports. Go to your computer firewall and you will see many more open ports. All for a specific purpose.
With something like OpenVPN, the open port is like offering your home address but the router/OpenVPN then confirms those knocking have a key (the encryption key of the VPN service) and is still protected by the firewall/antivirus; whereas opening a port that goes straight to BI/NVR/Camera is offering your home address and the front door is open with free access to go to town on getting in.
BI is great, but it doesn't have the millions of users like other programs, so a vulnerability could be sitting there longer before it is realized than say with Windows. And we shut off anti-virus for BI, so.....follow that path - port forward is not a good idea...
In another thread, someone used Censys Search to search for PCs that presented the Blue Iris login page and found almost 22,000 in the US and a total of about 32,000 worldwide. These are port-forwarded and many have been hacked.
Yes a traditional VPN requires an open port. The difference is that the VPN service requires an valid encryption key before traffic can pass through.
Think of it this way, the port forwarding always takes the incoming traffic and sends it to the desired destination. When that destination is a device that doesn't use an encryption key, that device will automatically accept ALL traffic. This means the only "security" that you have is whatever is built into the firmware/software of the device. When you are talking about most IOT devices, the firmwares are riddled with exploits and backdoors. When you use a traditional VPN service, the incoming traffic has to include the correct encryption key before that traffic can pass through. Without that valid encryption key, the traffic is simply dropped automatically. (In much the same way that incoming traffic to a firewall/router without any open ports is simply dropped by the network).
So using a VPN with a properly setup encryption key is MUCH more secure than simply port forwarding traffic to an unsecure port on your network.
Port forwarding is only as unsafe as the service you are exposing.
VPN servers are designed with cybersecurity as a top priority and most modern VPNs are generally considered safe by security experts, especially when the VPN server is kept up to date and uses modern best practices for cryptography-related settings.
Blue Iris's web server does not prioritize cybersecurity at the same level as a VPN server. It is not even close if we're being honest. That said, I personally trust Blue Iris's web server enough to forward a port to it and not bother with the VPN (because it IS an added hassle, there's no denying that). I would never do that for your typical IP camera or NVR appliance.
All of the security decisions are based on risk vs. hassle. For myself over the years, the anti-virus software has caused a lot more hassle than any virus has caused. The one virus I know I picked up blew right through the anti-virus software, and I quit using it about 10 years ago. My decision, likely condemned by almost everybody else.
So what's the risk of leaving a port open to a dedicated BI machine, and the likelihood of it happening?
1. The BI machine gets ruined and you have to rebuild it from scratch.
2. Some code infecting the BI machine turns it and all of your cameras into bots.
3. Some code infecting the BI machine gets into other computers on your network, resulting in stolen personal and banking information.
4. The BI machine gets ransomware and maybe spreads it to other machines on your network.
Everybody gets to make their own risk vs. hassle determination, I won't try to tell them what to think. My defense against #1 and #4 is to keep backups. The network setup defends against #2 and #3, but I realize there could be holes that could be exploited. And I'm not trying to defend having a port open, because I don't have a port open.
Tailscale (and zerotier which is a similar product) are great especially if your ISP doesn't give you a dedicated ipv4 address. Easier to set up than traditional VPN, and usually it "just works". But they can have speed issues on some networks if their normal firewall traversal methods fail because they fall back to a relatively slow proxied connection. Pfsense routers seem to be a problem due to the NAT method they use by default. I read about it in tailscale documentation and don't entirely understand, but it is fixable at least. pfSense settings to enable direct connections · Tailscale Docs
Reactions: gwminor48
I host Tailscale on pfSense and all I did was create the hybrid outbound NAT rule. Works automagically!
For example, Tailscale requires no port forwarding regardless of where it is hosted (router, firewall, OS client, etc.)
Then it uses P2P, which is as unsafe as servers that manage the connections. I'd guess that it has more risk than the "traditional" VPN, but the risk for both has a lot of zeros to the right of the decimal point.
This
Both are built on WireGuard btw.
You really think BI on a windows machine is inherently safer than a recent model Dahua NVR?
Have you seen the security section of them lately?
"How is a VPN more secure than port forwarding?"
Port Forwarding, think about it as a stargate from your living room to the worst neighborhood in the world. This is port forwarding.
Reactions: TechieTech
The real risk is #3. As soon as an experienced hacker gets access to an unencrypted service on your network, they are going to have complete access to everything on your network. You need to understand that the hackers of today aren't the "thrill seeking kids" of the 1970s/1980s who just wanted to see what they could do vs actually trying to cause mayhem. The majority of hackers today are "professionals" that are extremely knowledgeable and they earn their living by collecting/selling/ransoming data.
No one is going to knowingly do #1 without also doing the rest, and #2 & #4 aren't as important to a hacker as #3. It's normal for a hacker to eventually get around to #2 or #4, but only after scouring our network for private information. It's not just the risk that your personal information is stolen/copied without your knowledge. If the hacker is one of the many "ransom style" hackers out there, it could easily be the loss of all your pictures and other personal files (tax returns, etc). As a side note. ransom attacks are sophisticated. This isn't just some "virus" that you get that infects your computers automatically (although a virus is often how these attacks start). Once the hackers have a way into your network, they are going to probe it themselves. These aren't some "bots" doing all of this. These are real people that will access and explore your entire network. Now obviously making regular backups (and checking those backups to ensure they are failing to be made, and they aren't somehow corrupted) can protect you from the loss of data. But are you keeping those backups offline and off site? If not, your backups aren't going to help in a ransom style hack of your network (or an environmental event like a fire, flood, break-in, etc).
Now, I will be the first to admit that using a VPN service is not the "end all, be all" of network security. People on your network still need to refrain from clicking on the shit they get in emails, texts, and other delivery methods. The easiest hacks to accomplish are those that are started by a user "clicking" the wrong thing and inviting the hackers into their network. A VPN isn't going to prevent that from happening. That's the role of the virus detection software. So while you might consider virus detection software to be a waste of time, it is certainly an important layer of network security that shouldn't be ignored. In the same way, you shouldn't ignore the open doors (ports) into your local network either.
So while you may consider the risk small, it is well worth the effort to setup and use a VPN connection (and virus detection software). It is relatively easy to set up a self hosted VPN on your own network. Actually most network firewalls/routers support this functionality out of the box. There is honestly no excuse for NOT using a VPN. Just because you don't think you've been hacked before (there would be few signs that you were hacked if the hacker knew what they were doing and weren't interested in a ransom attack) doesn't mean it won't happen (again) in the future. If your security plan is based on the "obscurity" of your local network, that isn't security at all. That's the equivalent of living in a big neighborhood and leaving your doors unlocked because you assume any thief will go to your neighbor's houses first and never get to yours. It's completely random if/when your network is going to be probed by hackers. It certainly is worth the effort to be prepared for if/when it happens.
I learned this the hard way in a previous century when the backup media was the shiny brown stuff on reels. I had been blissfully backing up on tapes for at least a few months before I discovered that they were all blank, even though the software and tape deck looked and sounded like they were furiously writing everything. Part of my backup routine since then is to at least spot check if the stuff is really there.
