I have several Dahua Starlight 2 MP cameras that have been purchased through Andy over several years. Despite having good cameras, I find it hard to identify specific vehicles on our property at night. I'm planning on testing out an IR illuminator such as this one, after watching this video. I've got the cameras mounted in places that I don't want to run 120 volt power to power a wall wart and am trying to figure out how to power the illuminator from the same PoE feeding the camera (from a Unifi PoE switch). I've found PoE breakout devices such as this that split out 12 volt, 2 amp (optimistic is appears and it would appear that that would only be possible on a 802.3at switch) power from the PoE Ethernet. Unfortunately, it doesn't maintain PoE on the Ethernet cable coming from the device so I would have to use a 12V splitter such as this to power both the IR illuminator and the camera while still using the male RJ-45 for the data connection to the camera.
Is there a more elegant solution to this problem? I guess that I could run a second Ethernet cable only for the purpose of powering the IR illuminator with the PoE splitter, but it would be really nice to do power both devices from a single Ethernet run. The cameras are pulling 3 watts so even with the illuminator pulling the rated 12 watts, it seems like it is right on the limit of what can be run over 802.3af (15.4 watts for any of my 8-port unifi switches) with a little more headroom on a 802.3at switch (25.5 watts for my 24-port 250 watt unifi switch). While not as much illumination, I could downgrade to something like this illuminator, which supposedly only pulls 8 watts if I had to.
Also, have any of you found any other illuminators that you consider superior to the ones that I linked to?
Thanks for your thoughts.
Davidaj
Davidaj
