I need ideas, on where to install a camera at the entrance
What did you use to open up the 'hole' for the camera lens? Jigsaw? If so, that's an awfully steady hand you've got. ;)
Ha. At my age nothing is steady anymore. :p
An old neighbor who was an avid woodworker told me once that "all you need is a good jig". He's right.
Not sure if I figured this technique out on my own or saw on some show like "this old house", but you want to use a regular hole saw with a center arbor drill bit.
The obvious problem is there is no wood in the center for the arbor bit to bite into. You can solve that problem by clamping a scrap piece of wood behind the hole with a centering hole already drilled out. See pic below. This way the arbor bit is centered to the existing hole and it's easy to enlarge that hole. In this case I went with a 1.75" hole to eliminate the halo affect of the original hole size. You would need a bit bigger hole if you want to use the cam's IR lights. I've got some other project notes if others are interested. Can post here or in a separate thread as to not hijack the original poster.
Nice setup, and good idea.
Reactions: windguy
You get bonus points for doing it right AND explaining your method. MUCH appreciated.
@windguy love your birdhouse. Curious what you used for the base pole and how you ran cabling. Direct burial or regular cat5/6 in conduit in a hollow metal pole?
Finally (after seven months) got one of two birdhouse cams up and running. This T5442 6.0m cam is the approach to the entry area covering the driveway pad. Last one is painted and ready to go for the entry area but I've been using the T5442 3.6m cam for monitoring the veggie garden for rats and don't want to give it up just yet.
Two birdhouse pics below and one snapshot of a real life test of someone leaving ad crap on the doormat.
Many thanks to @tibimakai for pioneering this design and offering design help.
View attachment 69014View attachment 69013View attachment 69015
Reactions: windguy
Thanks. I plan to create a PDF build doc and will post here. Just haven't gotten to it yet. That will show some of those details you're asking about. Too much detail to post here now but will answer your specific questions in case you're looking to do this now and don't want to leave you hanging.
The pole I found at Home Depot. I preferred a round one but this one was in stock for only $10.98 and had a nice mounting flange for the base. Good enough.
Took the top plastic cap off and mounted it to the underside of the birdhouse base, which is 5/8" cedar fencing scrap. Drilled a hole through the center for cabling.
I created my own cement block for the base with four mounting bolts sticking up and a 1/2" center hole for the flex conduit. That was a fun project. 8"x8"x2.5".
I ran Cat 5 through 1/2 rigid PVC conduit buried along the edge of the foundation, about 30ft. Total run was about 80ft from POE inside the garage to this area. Ran two cables for two birdhouses. Used 1/2 flex at the end after splitting the lines in a Type-T conduit body.
Hope that helps.
No, I just need to repaint it.
I took a different approach for the same reason. I set up a bullet cam at ground level looking up. No one seems to notice as it looks pretty much like a landscape light. No problems with ball caps or hoodies obstructing a facial view either. You get a decent close up face shot every time as most people look out or down when walking and it does not ugly up the front entry at all. It provides a full view of the door and ground level packages and fewer false triggers not facing the road or other moving objects like trees or clouds. (Last pic is my "attack cat" guarding the entrance when I'm away.)
View attachment 51701View attachment 51702View attachment 51700
Do you have any pics of how you mounted this (yard stake, wood/stone block, etc.)? Also which short bullet model did you use, and did you paint it to look like typical landscape lights (black)?
